On 24/02/2011 at 13:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- Hey everyone. I have a question regarding the draw function of a tag plugin.
with my tag plugin I am trying to draw a circle around an object that the user has placed in to a link field in the tag attributes. When the user places any object in the link field, I want my tag to draw a circle around it. here is the code I am using.
BaseContainer* bc = tag->GetDataInstance(); if(!bc) return FALSE; BaseDocument *doc = bh->GetDocument(); if (!doc) return FALSE; objectToOrbit = bc->GetObjectLink(ORBIT_OBJECT_TO_ORBIT, doc); if (!objectToOrbit) return FALSE; Real position = bc->GetReal(ORBIT_POSITION); /**** DRAW THE ORBIT PATH ****/ Matrix m; Real rx = bc->GetReal(ORBIT_RADIUS_X); Real ry = bc->GetReal(ORBIT_RADIUS_Y); m.off = objectToOrbit->GetRelPos(); if(bc->GetLong(ORBIT_AXIS) == ORBIT_AXIS_X){ m.v1 = Vector(0, rx, 0); m.v2 = Vector(0, 0, ry); op->SetRelPos(objectToOrbit->GetAbsPos() + objectToOrbit->GetRad() + (Vector(0, rx, ry) * position)); } if(bc->GetLong(ORBIT_AXIS) == ORBIT_AXIS_Y){ m.v1 = Vector(rx, 0, 0); m.v2 = Vector(0, 0, ry); op->SetRelPos(objectToOrbit->GetAbsPos() + objectToOrbit->GetRad() + (Vector(rx, 0, ry) * position)); } if(bc->GetLong(ORBIT_AXIS) == ORBIT_AXIS_Z){ m.v1 = Vector(rx, 0, 0); m.v2 = Vector(0, ry, 0); op->SetRelPos(objectToOrbit->GetAbsPos() + objectToOrbit->GetRad() + (Vector(rx, ry, 0) * position)); } bd->DrawCircle(m);
for some reason, instead of drawing the circle around the object in the link field, it is drawing the object around the object on which the tag is placed. That is not my desired result. Does anyone see a reason why this would be happening? Am I doing something wrong with the DrawCircle() function or the Matrix that is involved.
Thanks,
Shawn
On 24/02/2011 at 16:34, xxxxxxxx wrote:
And interestingly... when I add the tag to an object, every object below that one in the Object Manager disappears in the viewport. Weird huh?
On 24/02/2011 at 18:06, xxxxxxxx wrote:
Howdy,
First of all, I don't think you should set an object's position in the draw function. What I'd suggest is create a class member variable:
Matrix drawMatrix;
... and set those values in another function.
Then in your draw function, you'd simply call:
bd->DrawCircle(drawMatrix);
Adios, Cactus Dan
On 25/02/2011 at 03:03, xxxxxxxx wrote:
Cool.. I'll give it a try.. Thanks Dan. :)
On 25/02/2011 at 03:21, xxxxxxxx wrote:
That did the trick. Thanks again Dan. !
On 25/02/2011 at 06:55, xxxxxxxx wrote:
You're welcome.
