On 23/02/2011 at 05:14, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Hi,
i want to copy a MultipassBitmap to my own Picturefile. Currently i use the GetPixelCnt function to get the Pixels LinePerLine, but it seems that i use it in the wrong way (on some PCs it crashs).
My Code:
void *linePtr = GeAlloc(sizeX*3); // the buffer where the Pixels per line are stored LONG BytesPerPixel = src->GetBt() / 8; // src is a MultipassBitmap * src->GetPixelCnt(0, y, sizeX, (UCHAR* )linePtr, BytesPerPixel, COLORMODE_RGB, PIXELCNT_0); // should copy the line to the buffer
Is it possible what the BytesPerPixel are wrong calculated (I thought the BytesPerPixel are the Bytes used for 1 Pixel in the src Bitmap => so get the bits per pixel and take it throw 8
On 23/02/2011 at 05:30, xxxxxxxx wrote:
Actually I I am not familiar with C++. What about the GetClone() function ? If you want to Copy the Bitmap, it might be useful.
//Ah, sorry. A MultipassBitmap is not the same as a BaseBitmap. Ignore my comment.
On 23/02/2011 at 05:33, xxxxxxxx wrote:
well i want to copy the data to my own (RGB 8bit) Pictureclass so i couldnt clone it.
On 23/02/2011 at 06:27, xxxxxxxx wrote:
The BFF.cpp SDK example uses the GetPixelCnt() method.
I stripped it down to following code:
LONG y,bw,bh; UCHAR *line = NULL; //bm is the bitmap bw=bm->GetBw(); bh=bm->GetBh(); line = GeAllocType(UCHAR,3*bw); if (!line) { GeFree(line); return FALSE; } for (y=0; y<bh; y++) { bm->GetPixelCnt(0,y,bw,line,COLORBYTES_RGB,COLORMODE_RGB,PIXELCNT_0); // do something with line } GeFree(line);
Always free the buffer with GeFree() when you are finished.
On 23/02/2011 at 07:04, xxxxxxxx wrote:
ah thanks,
could i dynamical determine which COLORBYTES an COLORMODE return by getColorMode() has?
On 23/02/2011 at 07:31, xxxxxxxx wrote:
Originally posted by xxxxxxxx could i dynamical determine which COLORBYTES an COLORMODE return by getColorMode() has?
Not that I know of. You have to convert COLORMODE to COLORBYTES yourself.
something like this:
switch (mode) { case COLORMODE_RGB: return COLORBYTES_RGB; case COLORMODE_GRAY: return COLORBYTES_GRAY; // etc. }
On 23/02/2011 at 07:33, xxxxxxxx wrote:
ah ok thank you very much.
