Selected Keys? Move Keys?
    On 27/02/2011 at 08:05, xxxxxxxx wrote:
    Trying to move this on in a more modular way
    ie have a  function for each transformation on selected keys
    just wondered if I was heading in the right direction???
    (ignore print checkpoints just for testing)
    Next objective to 'nudge' everything back
    as 'everything' gets moved over by staggering process
    ie first track shouldnt move - everything else - stagger
    Updated version in later post
    On 01/03/2011 at 00:42, xxxxxxxx wrote:
    Making an effort to understand what I'm seeing
    Line 14 function call within itself - seems incorrect?
    MoveSelectedKeys(op,offset,timeln)
    On 01/03/2011 at 07:21, xxxxxxxx wrote:
    I am sorry, I may can go to my pc this weekend, but not earlier.
    Does the Console tell you this ? O.o
    If A function calls itself, everything starts again. But you may have changed some values before. (Here the timeln variable)
    On 02/03/2011 at 01:03, xxxxxxxx wrote:
    Can anyone tell me why this message
    doesn't pop up if NO object is selected using the function from the code above?
    lst = GetActiveObjects(doc)
        op = lst[0]
        if not op:
            gui.MessageDialog("No objects selected")
            return False #leave the script if not an object
    On 02/03/2011 at 02:37, xxxxxxxx wrote:
    Dunnoo .. Gonna test this this weekend. Maybe it's because op = lst[0] ist not in the right column ?
      op = lst[0] ## here
        if not op:
    On 02/03/2011 at 03:03, xxxxxxxx wrote:
    Hi Nux
    nope, not that - must be forum paste incorrect
    indent is as your example
    appreciate you can't test at moment
    I think its to do with this function setting op to the first object in doc
    if nothing selected
    that way op is never NULL
    def GetActiveObjects(doc) :
        lst = list()
        op = doc.GetFirstObject()
        while op:
            if op.GetBit(c4d.BIT_ACTIVE) == True: lst.append(op)
            op = GetHNext(op)
        return lst
    On 02/03/2011 at 03:22, xxxxxxxx wrote:
    the list only gets appended if op is selected.
    On 03/03/2011 at 06:11, xxxxxxxx wrote:
    And this is where I'm at so far
    Ignore some Print items - just for console checks
    Still trying to make it modular
    ie have a function for each type of key transform - (just stagger in this one)
    appreciate any advice on good/bad code form
    added gui to take offset
    count selected objects - need more than 2
    and now first object doesnt get offset (its popped off array)
    def MoveSelectedKeys(op,offset,timeln = 1) :    # offset in frames
        if (not op) or (not offset) : return False
        if timeln == 1: timeln = c4d.NBIT_TL1_SELECT
        elif timeln == 2: timeln = c4d.NBIT_TL2_SELECT
        elif timeln == 3: timeln = c4d.NBIT_TL3_SELECT
        elif timeln == 4: timeln = c4d.NBIT_TL4_SELECT
            import math
            timeln = math.fmod(timeln,4)
        doc = op.GetDocument()
        track = op.GetFirstCTrack()
        if not track: return False
        fps = float(doc.GetFps())
        while track:
            curve = track.GetCurve()
            cnt = curve.GetKeyCount()
            for i in xrange(cnt) :
                key = curve.GetKey(i)
                if key.GetNBit(int(timeln)) == True:
                    tme = key.GetTime()
                    key.SetTime(curve,c4d.BaseTime(offset/fps+tme.Get()))
            track = track.GetNext()
        c4d.EventAdd(c4d.MSG_UPDATE)
    def GetLastSelectedKey(track, timeln = 1) :
            import math
            key = curve.GetKey(cnt-i-1)
                return key
    ####################################MINE
    def GetFirstSelectedKey(track, timeln = 1) :
            import math
        key = curve.GetKey(0)
            return key
    def GetHNext(op) :
        if not op: return
        if op.GetDown() : return op.GetDown()
        while not op.GetNext() and op.GetUp() :
            op = op.GetUp()
        return op.GetNext()
        lst = list()
        while op:
            op = GetHNext(op)
        return lst
    #####################################MINE
    def Stagger(doc,op,lst,keylast,overlap) :
        print "Length of list before pop", len(lst)
        lst.pop(0)  #remove the first object as its not moved
        op = lst[0] #get fist active object again, less original first object
        print "Length of list after pop", len(lst)
        offset = keylast.GetTime().GetFrame(doc.GetFps())-overlap
        for i in xrange(len(lst)) : #increment through allthe objects selected
            doc.AddUndo(c4d.UNDOTYPE_CHANGE,op)
            MoveSelectedKeys(op,offset) #moves all the selected keys on a track
            keylast = GetLastSelectedKey(op.GetFirstCTrack())
            if not keylast: offset = 0
            # the original cal moved everything # else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
                print "OS1", offset
                print "OS2", offset
            # object namecheck # print op.GetName()
            if  i+1 < len(lst) : # +1 stops index going out of range ie more objects than listed
                op = lst[i+1]# ok to get next object in list
    def main() :
        from c4d import documents
        from c4d import gui
        c4d.CallCommand(1024314); # clear the python console
        # get a value form the user
        guival = gui.InputDialog("Enter a value < your max keyspan","10")
        print "Dialog Value =",guival
        overlap = int(guival)
        doc = documents.GetActiveDocument()
        doc.StartUndo()
        lst = GetActiveObjects(doc) #get selected objects
        print "List Length = ", len(lst)
        if len(lst)<=1:
            c4d.gui.MessageDialog("You need to select at least two objects")
            return False #leave if not enough objects selected
        keyfirst = GetFirstSelectedKey(op.GetFirstCTrack())
        keyfirstval = keyfirst.GetTime().GetFrame(doc.GetFps())
        keylastval = keylast.GetTime().GetFrame(doc.GetFps())
        keyspanval = keylastval - keyfirstval
        print "Selected Keyspan 1st track = ", keyspanval
        print "Keytime of start key = ", keyfirstval
        print "Keytime of end key = ", keylastval
        ##### else do the stagger
        else: Stagger(doc,op,lst,keylast,overlap)
        doc.EndUndo()
    if __name__=='__main__':
    On 06/03/2011 at 08:05, xxxxxxxx wrote:
    Any feedback on programing 'form' would be appreciated.
    Think it would be useful to have a couple more transformations
    Stagger2 - enter total stagger length - x frames (rather than current overlap in frames)
    Accelerate - gradually space out over x frames
    Decelerate - reverse above
    Stack - thats essentially stagger with no overlap?
    On 06/03/2011 at 10:29, xxxxxxxx wrote:
    Well, works fine. If you want potential increament for eg. you need to calculate something with the offset value. ;-)
    On 06/03/2011 at 11:09, xxxxxxxx wrote:
    cheers Nux
