Mirror Tool Bug?
On 13/02/2011 at 16:22, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform:
I've had this long standing problem with the Structure->Mirror tool with Coffee. And I'm getting the same results now that I'm using C++.
The problem is only the execution part works. But none of the various parameters allow me to change them.
I don't know if I'm writing the code wrong. Or if it's a bug.
All I know is that I can use the same code structure on other things and it works fine.BaseObject* op = doc->GetFirstObject(); BaseContainer bc; ModelingCommandData mcd; mcd.bc = &bc; mcd.doc = doc; mcd.op = op; mcd.flags = MODELINGCOMMANDFLAGS_CREATEUNDO; mcd.mode = MODELINGCOMMANDMODE_POINTSELECTION; // points option //mcd.mode = MODELINGCOMMANDMODE_POLYGONSELECTION; // polygons option //mcd.mode = MODELINGCOMMANDMODE_ALL; // All option bc.SetLong(MDATA_MIRROR_SYSTEM, 1);// Set World option----------->No Response bc.SetLong(MDATA_MIRROR_PLANE, 2);// Set XZ option--------------->No Response bc.SetBool(MDATA_MIRROR_ONPLANE, TRUE);//Enable symmetry option-->No Response bc.SetData(MDATA_MIRROR_VALUE, 100);// Set value option---------->No Response bc.SetBool(MDATA_MIRROR_WELD, TRUE); //Enable Weld option-------->No Response if (!SendModelingCommand(MCOMMAND_MIRROR, mcd)) return FALSE; EventAdd();//Update all the changes
BTW: I've also tried using WORLD & XZ as parameters in the two SetLong parameters. And they still won't work for me. And it's the same result no matter which mode(points,polygons,all) I use.
Is this a bug?
Or is it user error?-ScottA
On 14/02/2011 at 02:51, xxxxxxxx wrote:
I can confirm that it doesn't take the values of the BaseContainer into account. I will forward this to the developers.
cheers,
Matthias
On 14/02/2011 at 07:20, xxxxxxxx wrote:
Thank you Matthias.
