How to access in the layer shader
On 07/02/2011 at 03:00, xxxxxxxx wrote:
Hi folks,
my first post here , and like always it's a question.
I'm quite sure it is as easy as hell for u pros, but as a beginner I'm stuck.
I'm currently doing a tiny, nifty plugin that replaces all texturepaths at once.
It should be just like "Smart Texpath", but I'm doing that for Vray Materials as well.
One way a good coding girl found was to look for the "BITMAPSHADER_FILENAME" and the channels (eg. VRAYMATERIAL_COLOR_SHADER)
However I need to go in the layer shader to complete this plugin, is there anyway "attack"/access it ?
Or another thought of mine: is it possible to get into the texturelist the Selection/Structure Window ?
Via Id 14011 I can access Selection/Structure Window but what is the way to access the texture list ?
Any help is much appreciated.
On 07/02/2011 at 11:48, xxxxxxxx wrote:
You need to browse the shaders of the material recursively, like so:
def GetMaterials(shd) :
    if shd == None: return
    #Do Something
    print shd.GetName()
    if shd.GetType() == c4d.Xbitmap:
        print shd[c4d.BITMAPSHADER_FILENAME]
    #Recurse
    if shd.GetDown() : GetMaterials(shd.GetDown())
    if shd.GetNext() : GetMaterials(shd.GetNext())
def main() :
    mat = doc.GetActiveMaterial()
    shd = mat.GetFirstShader()
    GetMaterials(shd)
On 08/02/2011 at 01:25, xxxxxxxx wrote:
thank you very much Rick,
you made my day.
And as always, is that simple for u pros !
Since I was using the old python in R11.5 I did not stumble upon that.
Arr and that's where things getting tricky.
Is there any chance to get this working in R11.5 ?
Maybe via Coffee or  C++ when the chips are down?
Thanks for your time
On 08/02/2011 at 09:47, xxxxxxxx wrote:
You can certainly do it in C++, but COFFEE has no access to the layer shader or the shader tree.
On 09/02/2011 at 01:10, xxxxxxxx wrote:
arr bad news,
alright so I will stick with py4d in R12.
Cheers and thanks for your patience
