Decimal
    On 19/01/2011 at 16:42, xxxxxxxx wrote:
    does anyones know how to change the decimal precision of vector's number? I'm tryng to read a cloud of points from an external ascii document and is very important to have a least of 8 decimals.
    It seems to me that cinema 4d work always with 3 decimals. Is it possible to increase the accuracy?
    I've found this command "getcontext().prec = n" in a python documentation but doesn't work.
    Anyone got any ideas?
    Thank you.
    Luther
    On 20/01/2011 at 02:37, xxxxxxxx wrote:
    Hi, the numbers are just cut off for the user. Internally C4D uses double precision.
    On 20/01/2011 at 07:44, xxxxxxxx wrote:
    thank you for your answer. I had guessed as much! Is ti possible in python to unlock this limitation, for example when I print the coordinates of a vector?
    On 20/01/2011 at 14:16, xxxxxxxx wrote:
    Printing the coordinates of a vector should be fine from scratch:
    p=c4d.Vector(1.2345678)
    print p.x #output 1.2345678
