Animation position/rotation using Python
    On 15/01/2011 at 14:27, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:   Windows  ;
    Language(s) :       PYTHON  ;
    New to C4D but very experienced elsewhere. I'm trying to animate objects' position and rotation through the python API. I'll have to animate some other things eventually too. I tried using the typical approach of document.SetTime and SetAbsPos, but that didn't seem to have any effect. Is there a recording flag that needs to be turned on? Or are CTrack and CKey supposed to be used---but how? I see some forum posts relating to this involving DescIDs, where is the (meaningful) documentation for this? (in any programming language) Can switch to COFFEE if really necessary, but C++ is unacceptable for this application. Thanks.
    On 15/01/2011 at 20:28, xxxxxxxx wrote:
    Well,  I can show you the code I use to rotate my planet objects in PXG.   It is using C++ but it might help you with Python.
    //ROTATE PLANET
    Bool PlanetXObject::RotatePlanet(BaseObject *op, GeListNode* node){
      if (!op) return FALSE;
      BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance();
      if (!bc) return FALSE;
      BaseDocument *doc = op->GetDocument();
      if(!doc) return FALSE;
      BaseTime time = doc->GetTime();
      Real fps = doc->GetFps();
      //Rotation Track Vector
      DescID idRotX = DescID(DescLevel(ID_BASEOBJECT_REL_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0));
      //Planet COUNTER CLOCKWISE Rotation
      if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
          bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_COUNTER_CLOCKWISE){
          //Remove Existing Track
          if (op->FindCTrack(idRotX)){
              op->FindCTrack(idRotX)->Remove();
          //Insert the New Track
          CTrack *track = op->FindCTrack(idRotX);
          if (!track){
              track = CTrack::Alloc(op,idRotX);
              if (!track) return FALSE;
              op->InsertTrackSorted(track);
          //Get the Base Time
          BaseTime bstime = time;
          //Set the Frame Rate (FPS)
          bstime.SetDenominator(fps);
          Real deNomin;
          deNomin = (60 *fps) / bc->GetReal(PLANETX_GENERAL_ROTATION_SPEED);
          //First Key will be set at 0
          bstime.SetNumerator(0);
          CKey *keyH = track->GetCurve()->AddKey(bstime,0);
          if (!keyH) return false;
          keyH->SetValue(track->GetCurve(),0); //Set Position to 0
          //Second Key will be placed at deNomin
          bstime.SetNumerator(deNomin);
          CKey *keyH2 = track->GetCurve()->AddKey(bstime,0);
          if (!keyH2) return false;
          keyH2->SetValue(track->GetCurve(),6.283185307); //Set Position to 360
          track->SetAfter(CLOOP_REPEAT);
      //Planet CLOCKWISE Rotation
      else if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
               bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_CLOCKWISE)
          if (!track)
          //Get the Base Time
          Real deNomin;
          keyH->SetValue(track->GetCurve(),6.283185307); //Set Position to 360
          //Second Key will be placed at 3 times the location of the frame rate
          //(i.e. if FPS is set to 30, then the key will be placed at frame 45.
          keyH2->SetValue(track->GetCurve(),0); //Set Position to 0
      else
          //If the track exists remove it!
      return TRUE;
    Hope that helps you.  :)
    On 20/01/2011 at 23:26, xxxxxxxx wrote:
    This will show you the very basics:
    obj = op.GetObject()
    def main() :
        t = doc.GetTime().Get()
        pos = c4d.Vector(0,t*100, 0)
        rot = c4d.Vector(0,t,0)
        obj.SetAbsPos(pos)
        obj.SetAbsRot(rot)
