On 15/01/2011 at 10:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10+ Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Howdy,
How do you allocate a PLA track and set keys?
I searched the forum and found this thread: https://plugincafe.maxon.net/topic/2224/1577_pla-animation-in-c&KW=PLAKey
.... but the code presented there is not working.
First of all, I can not find "ID_ANIM_PLA" anywhere in any header files on my machine, so I created a test to find out what the ID was of a PLA track to be sure it was the same as stated in that thread:
BaseObject *op = doc->GetActiveObject(); CTrack *trk = op->GetFirstCTrack(); if(trk) { DescID dscID = trk->GetDescriptionID(); GePrint(DescIDToString(dscID)); }
... which confirmed the ID number was the same.
Then I tried to allocate a PLA for a polygon object like this:
#define ID_PLA_TRACK 100004812 DescID trkID = DescID(ID_PLA_TRACK,ID_PLA_TRACK,0); CTrack *track = op->FindCTrack(trkID); if(!track) { track = CTrack::Alloc(op,trkID); if(track) op->InsertTrackSorted(track); else GePrint("Could not allocate PLA track for "+op->GetName()); }
... and it always fails.
Adios, Cactus Dan
On 15/01/2011 at 12:37, xxxxxxxx wrote:
Well here is the contents of ckpla.h maybe they changed the names of those constants since then.
#ifndef _CKPLA_H_ #define _CKPLA_H_ enum { CK_PLA_BIAS = 10001, // real CK_PLA_CUBIC = 10002, // bool CK_PLA_DATA = 10003, CK_PLA_DUMMY }; #endif
EDIT: Scratch that.. The second two are part of ckpla.h I can't find ID_ANIM_PLA either lol.
On 15/01/2011 at 12:48, xxxxxxxx wrote:
#ifdef C4D_R10 #ifdef XCODE enum { ID_ANIM_PLA = 100004812L }; #include "ckpla.h" #else #include "newman\res\c4d_symbols.h" #include "newman\res\description\ckpla.h" #ifdef C4D_R105 #define ID_ANIM_PLA CTpla #endif #endif #endif // Fix Animation onto Polygon object as PLA track //*---------------------------------------------------------------------------* Bool IPPFix::FixPolygonAnimation(PointObject* orig, PointObject* root, LONG* partial, LONG elements) //*---------------------------------------------------------------------------* { // Get Destination point array Vector* dpoint = root->GetPointW(); if (!dpoint) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_GENERAL_TEXT), "FixPolygonAnimation.root", "Has No Points"); // Check for Spla track, create if none DescID descID = DescLevel(ID_ANIM_PLA,ID_ANIM_PLA,0L); CTrack* track = root->FindCTrack(descID); if (!track) { track = CTrack::Alloc(root, descID); if (!track) return ErrorException::OOMThrow(EE_DIALOG, GeLoadString(IPPERR_MEMORY_TEXT), "FixPolygonAnimation.track"); root->InsertTrackSorted(track); doc->AddUndo(UNDOTYPE_NEW, track); } BaseTime stime = doc->GetMinTime(); BaseTime etime = doc->GetMaxTime(); CCurve* seq = track->GetCurve(); if (!seq) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MEMORY_TEXT), "FixPolygonAnimation.seq"); seq->FlushKeys(); // Sample Animation at AnimSample intervals ModelingCommandData mcd; mcd.doc = doc; mcd.op = orig; BaseContainer mbc; mbc.SetBool(MDATA_CURRENTSTATETOOBJECT_INHERITANCE, TRUE); mbc.SetBool(MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, FALSE); mcd.bc = &mbc; mcd.flags = MODELINGCOMMANDFLAGS_0; BaseObject* csto = NULL; PointObject* defd = NULL; CKey* key = NULL; const Vector* spoint = NULL; Vector* points = NULL; Vector* lpoints = NULL; DescID biasDID = DescLevel(CK_PLA_BIAS, DTYPE_REAL,0L); DescID cubicDID = DescLevel(CK_PLA_CUBIC, DTYPE_BOOL,0L); LONG pointCount = root->GetPointCount(); LONG pointSize = pointCount*sizeof(Vector); Real fps = doc->GetFps(); LONG startf = stime.GetFrame(fps); LONG endf = etime.GetFrame(fps); StatusSetText("Fixing Animation for "+orig->GetName()); for (; startf <= endf; startf += AnimSample) { stime = BaseTime::BaseTime(startf, fps); // - Animate Document to change the points of orig doc->SetTime(stime); #ifdef C4D_R12 doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0); #else doc->AnimateDocument(NULL, TRUE, TRUE); #endif EventAdd(); // Current State to Object if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation"); csto = static_cast<BaseObject*>(mcd.result->GetIndex(0)); AtomArray::Free(mcd.result); if (!csto) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation.csto"); if (csto->IsInstanceOf(Onull)) { defd = ToPoint(csto->GetDown()); if (!defd) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation.defd"); } else defd = ToPoint(csto); // - Add KeyFrame key = seq->AddKey(stime); if (!key) { BaseObject::Free(csto); return ErrorException::OOMThrow(EE_DIALOG, GeLoadString(IPPERR_MEMORY_TEXT), "FixPolygonAnimation.key"); } doc->AddUndo(UNDOTYPE_NEW, key); // - Add PLA data // + R10 spoint = defd->GetPointR(); if (!spoint) { GePrint("Source Obj has no Points"); BaseObject::Free(csto); break; } // Apply parent animation to points points = defd->GetPointW(); lpoints = points+pointCount; for (; points != lpoints; ++points) (*points) *= orig->GetMg(); #ifdef OS64 CopyMem(spoint, dpoint, static_cast<VLONG>(pointSize)); #else CopyMem(spoint, dpoint, pointSize); #endif // - R10 if (!track->FillKey(doc,root,key)) { BaseObject::Free(csto); return ErrorException::Throw(EE_DIALOG, "FixPolygonAnimation.FillKey failed"); } // Do these AFTER FillKey()! key->SetParameter(biasDID, GeData(AnimBias), DESCFLAGS_SET_0); key->SetParameter(cubicDID, GeData(AnimSmooth), DESCFLAGS_SET_0); BaseObject::Free(csto); // Update progress bar on each frame StatusSetBar(((*partial)*100L)/elements); ++(*partial); } // Ended at last frame - done if (startf == endf) { // Clear global matrix root->SetMg(unitMatrix); return TRUE; } // Cap last frame with PLA key stime = BaseTime::BaseTime(startf, fps); // - Animate Document to change the points of orig doc->SetTime(stime); #ifdef C4D_R12 doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0); #else doc->AnimateDocument(NULL, TRUE, TRUE); #endif EventAdd(); if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd)) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation"); csto = static_cast<BaseObject*>(mcd.result->GetIndex(0L)); AtomArray::Free(mcd.result); if (!csto) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation.csto"); if (csto->IsInstanceOf(Onull)) { defd = ToPoint(csto->GetDown()); if (!defd) return ErrorException::Throw(EE_DIALOG, GeLoadString(IPPERR_MODELINGCOMMAND_TEXT), "FixPolygonAnimation.defd"); } else defd = ToPoint(csto); // - Add KeyFrame key = seq->AddKey(stime); if (!key) { BaseObject::Free(csto); return ErrorException::OOMThrow(EE_DIALOG, GeLoadString(IPPERR_MEMORY_TEXT), "FixPolygonAnimation.key"); } doc->AddUndo(UNDOTYPE_NEW, key); // - Add PLA data // + R10 spoint = defd->GetPointR(); if (!spoint) { GePrint("Source Obj has no Points"); BaseObject::Free(csto); return TRUE; } // Apply parent animation to points points = defd->GetPointW(); lpoints = points+pointCount; for (; points != lpoints; ++points) (*points) *= orig->GetMg(); #ifdef OS64 CopyMem(spoint, dpoint, static_cast<VLONG>(pointSize)); #else CopyMem(spoint, dpoint, pointSize); #endif // - R10 if (!track->FillKey(doc,root,key)) { BaseObject::Free(csto); return ErrorException::Throw(EE_DIALOG, "FixPolygonAnimation.FillKey failed"); } // Do these AFTER FillKey()! key->SetParameter(biasDID, GeData(AnimBias), DESCFLAGS_SET_0); key->SetParameter(cubicDID, GeData(AnimSmooth), DESCFLAGS_SET_0); BaseObject::Free(csto); // Clear global matrix root->SetMg(unitMatrix); return TRUE; }
On 15/01/2011 at 15:12, xxxxxxxx wrote:
Howdy,
Actually, I came up with something that works, and is easier to implement:
AutoAlloc<AliasTrans> trans; #if API_VERSION < 12000 BaseObject *opClone = (BaseObject* )op->GetClone(0,trans); #else BaseObject *opClone = (BaseObject* )op->GetClone(COPYFLAGS_0,trans); #endif Bool autoKeyOn = IsCommandChecked(IDM_AUTOKEYS); if(!autoKeyOn) CallCommand(IDM_AUTOKEYS); Bool plaKeyOn = IsCommandChecked(IDM_A_PLA); if(!plaKeyOn) CallCommand(IDM_A_PLA); CalculatePoints(op); op->Message(MSG_UPDATE); doc->SetTime(time); doc->AutoKey(opClone,op,FALSE,FALSE,FALSE,FALSE,FALSE,TRUE); if(!autoKeyOn) CallCommand(IDM_AUTOKEYS); if(!plaKeyOn) CallCommand(IDM_A_PLA); BaseObject::Free(opClone);
It's probably not the most efficient way to do it, but it does work.
