CTrack questions
    On 15/01/2011 at 08:17, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:   Windows  ;
    Okay so I have a function that worked 100% in R11.5 but does not do anything in R12.  The function rotates the active object at the speed specified based on the current framerate.
    I assume that somehting has changed in the timeline/ CTrack ...     Here's is the code that worked in R11.5.   Does anyone see any reason why it wouldn't work in R12?   I'm not asking you to debug the whole thing.  I am asking you to look to see if there is something in this code that has changed in the r12 sdk..   That will at least help me pin point what I should be looking at.
    Thanks so much,.
    //ROTATE PLANET
    Bool PlanetXObject::RotatePlanet(BaseObject *op, GeListNode* node){
      if (!op) return FALSE;
      BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance();
      if (!bc) return FALSE;
      BaseDocument *doc = op->GetDocument();
      if(!doc) return FALSE;
      BaseObject* prnt = doc->GetActiveObject();
      if(!prnt) return FALSE;
      BaseTime time = doc->GetTime();
      Real fps = doc->GetFps();
      //Planet COUNTER CLOCKWISE Rotation
      if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
          bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_COUNTER_CLOCKWISE){
          //Remove Existing Track
          if (prnt->FindCTrack(DescID(DescLevel(myID,DTYPE_VECTOR,0), DescLevel(VECTOR_Z,DTYPE_REAL,0)))){
              prnt->FindCTrack(DescID(DescLevel(myID,DTYPE_VECTOR,0), DescLevel(VECTOR_Z,DTYPE_REAL,0)))->Remove();
          //Insert the New Track
          CTrack *track = prnt->FindCTrack(DescID(DescLevel(myID,DTYPE_VECTOR,0), DescLevel(VECTOR_Z,DTYPE_REAL,0)));
          if (!track){
              track = CTrack::Alloc(prnt,DescID(DescLevel(myID,DTYPE_VECTOR,0), DescLevel(VECTOR_Z,DTYPE_REAL,0)));
              if (!track) return FALSE;
              prnt->InsertTrackSorted(track);
              //Get the Base Time
              BaseTime bstime = time;
              //Set the Frame Rate (FPS)
              bstime.SetDenominator(fps);
              Real deNomin;
              deNomin = (60 *fps) / bc->GetReal(PLANETX_GENERAL_ROTATION_SPEED);
              //First Key will be set at 0
              bstime.SetNumerator(0);
              CKey *keyH = track->GetCurve()->AddKey(bstime,0);
              if (!keyH) return false;
              keyH->SetValue(track->GetCurve(),0); //Set Position to 0
              //Second Key will be placed at deNomin
              bstime.SetNumerator(deNomin);
              CKey *keyH2 = track->GetCurve()->AddKey(bstime,0);
              if (!keyH2) return false;
              keyH2->SetValue(track->GetCurve(),6.283185307); //Set Position to 360
              track->SetAfter(CLOOP_REPEAT);
      //Planet CLOCKWISE Rotation
      else if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
               bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_CLOCKWISE)
          if (!track)
              //Get the Base Time
              Real deNomin;
              keyH->SetValue(track->GetCurve(),6.283185307); //Set Position to 0
              //Second Key will be placed at 3 times the location of the frame rate (i.e. if FPS is set to 30, then the key will be placed at frame 45.
              keyH2->SetValue(track->GetCurve(),0); //Set Position to 360
      else
          if (prnt->FindCTrack(DescLevel(myID,DTYPE_REAL,0)))
              prnt->FindCTrack(DescLevel(myID,DTYPE_REAL,0))->Remove();
    PS this code compiles fine in R12 but does not rotate the object at all.   :)
    On 15/01/2011 at 12:56, xxxxxxxx wrote:
    Solved this.   I just declared,
    DescID idRotY = DescID(DescLevel(ID_BASEOBJECT_REL_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0));
    and replaced all DescID calles with   idRotY
