On 07/01/2011 at 07:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5 Platform: Language(s) : C.O.F.F.E.E ;
--------- Hello Guys, i want to write an ExpressionTagPlugin. Except of the Execute-Function everthing works fine, and i can't fingure out why ..
var i; class tPI : ExpressionPluginTag { public: tPI(); GetID(); MultipleAllowed(); DisplayAllowed(); GetIcon(); GetHelpText(); UseMenu(); GetName(); Execute(doc,op); } tPI::tPI() { super(); } tPI::GetID() { return TAG_ID; } tPI::MultipleAllowed() { return false; } tPI::DisplayAllowed() { return true; } tPI::GetIcon() { return icon; } tPI::GetHelpText() { return "something..."; } tPI::UseMenu() { return true; } tPI::GetName() { return TAG_NAME; } tPI::Execute(doc,op) { i++; println(i); }
Thanks in advance, nux
On 07/01/2011 at 17:48, xxxxxxxx wrote:
Nobody got an idea?
On 07/01/2011 at 19:32, xxxxxxxx wrote:
Hello nux, I felt bad for you not getting any help. So I registered here so I could give you a hand.
First - your i variable isn't declared with any data. So the program doesn't know what to do with when you ask it to increment it using i++. It doesn't know if it is an integer type, string type , vector type, etc...
Second- After you fix that problem with var i =0; You'll end up running an infinite loop the way it's written inside of your execute function.
Here's a working example based on what you're trying to do. Name it something like mytag.cof and put it in your plugins folder. Then open C4D--> open the console--> create an object-->Then add the tag. You should see the results of the execute function happen in the console:
const var PLUGIN_ID = 1000009; //Testing ID ONLY!!!! var tagIcon;
var i = 0; // Setting this to zero makes the program understand that this is a numeric value type class myTag : ExpressionPluginTag // the myTag's class { public: myTag(); GetID(); MultipleAllowed(); DisplayAllowed(); GetIcon(); GetHelpText(); UseMenu(); GetName(); Edit(); Execute(doc, op); }
myTag::myTag() { // Call parent constructor super(); }
myTag::GetID() { return PLUGIN_ID; } myTag::MultipleAllowed() { return TRUE; } myTag::DisplayAllowed() { return TRUE; } myTag::GetIcon() { return tagIcon; } myTag::GetHelpText() { return "This is my expression tag plugin"; } // Bubble help text. If option is turned on in the preferences myTag::UseMenu() { return TRUE; } myTag::GetName() { return "My Expression Tag"; } //The text displayed for the tag in the OM/ and lower right corner of UI
myTag::Edit() { //put any initalization type of code in here..... }
myTag::Execute(doc, op) { if(i<20) // This will stop once it reaches the value of 20..No infinite looping { i++; println(i); }
EventAdd(); //This will make the code automatically run, without scrubbing the slider, until it reaches the value of 20 return; }
///////// // Main
main() { // Get the icon //var fn = GeGetRootFilename(); //fn->RemoveLast(); //fn->AddLast("xrayicon.tif");
//tagIcon = new(BaseBitmap,1,1); //tagIcon->Load(fn);
// Registers the tag Register(myTag); }
I commented out the bitmap map stuff at the bottom so it will run. I have some more simple examples. If you want them send me an e-mail at [email protected]
Hope this helps you out, -ScottA
On 08/01/2011 at 03:44, xxxxxxxx wrote:
I've rewritten the Plugin along your explanations, and it works, thanks man !!! Dunno where my Issue was, but most important is, it works !! *I'm glad*
