On 03/01/2011 at 11:29, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hi,
I found this message type to be very useful in order react on changing resource parameters. But how can I get the corresponding resource ID from the DescriptionPostSetValue structure?
On 05/01/2011 at 13:26, xxxxxxxx wrote:
No way?
On 06/01/2011 at 09:04, xxxxxxxx wrote:
// NodeData.Message //*---------------------------------------------------------------------------* Bool GreeblerObj::Message(GeListNode* node, LONG type, void* data) //*---------------------------------------------------------------------------* { //GePrint(MsgToString(type)); if (!node) return FALSE; if (type == MSG_DESCRIPTION_GETBITMAP) return MsgGetBitmap(static_cast<DescriptionGetBitmap*>(data), static_cast<BaseObject*>(node)); else if (type == MSG_DESCRIPTION_COMMAND) return MsgCommand(static_cast<DescriptionCommand*>(data), static_cast<BaseObject*>(node)); else if (type == MSG_DESCRIPTION_POSTSETPARAMETER) return MsgPostSetParameter(static_cast<DescriptionPostSetValue*>(data), static_cast<BaseObject*>(node)); ... }
//*---------------------------------------------------------------------------* Bool GreeblerObj::MsgPostSetParameter(DescriptionPostSetValue* dpsv, BaseObject* op) //*---------------------------------------------------------------------------* { if (!(dpsv && op)) return TRUE; BaseContainer* bc = op->GetDataInstance(); LONG id = (*(dpsv->descid))[0].id; if ((id == GREEBLER_BASE_HEIGHT_MIN) || (id == GREEBLER_BASE_HEIGHT_MAX)) { ... }
On 06/01/2011 at 09:29, xxxxxxxx wrote:
was already closed to thanks.
