HTML Viewer [SOLVED]
On 03/01/2011 at 09:45, xxxxxxxx wrote:
ResEdit Version:   R8
Hi guys, just a tiny question:
With ResEdit one can create "C4D Field" (Is it called so ?).
One can choose a type called "HTML Viewer". But nowhere is described how to initialise the field.
Does anyone know about it ?
Thanks in advance, lg nux
On 04/01/2011 at 00:29, xxxxxxxx wrote:
Hello nux,
In the Cinema4DR12SDK  you will find HTMLViewerCustomGui, maybe that helps. ;)
On 04/01/2011 at 01:23, xxxxxxxx wrote:
The Functions from the C++ SDK for the HTML Viewer don't work in COFFEE :(
Or do I use them wrong ?
There is no ID variable in the Function SetUrl(), so i Just "added" it as it is in all other Functions for COFFEE for Dialogs. 😂
This is my Init() Function of the Dialog:
Dialog::Init() {
  var file = GeGetRootFilename();
  file->RemoveLast();
  file->AddLast(PATH);
  var url = FilenameToURL(file);
  SetURL(USR_HTML,file,URL_ENCODING_UTF16);
  return true;
On 04/01/2011 at 08:33, xxxxxxxx wrote:
COFFEE doesn´t support it.
On 05/01/2011 at 06:07, xxxxxxxx wrote:
Oh man .. -.-'
So it's going to be time to learn C++ ..
Thanks Katachi,
greets, nux
