On 03/01/2011 at 02:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : PYTHON ;
--------- Hi everyone this my first post i try use in plugins.ObjectData i want take the doc becuase i want take the time frame in this example `` i know this dosen't work correct ``class MyMain(plugins.ObjectData) : def GetVirtualObjects(self, op, hh) : **doc=documents.GetActiveDocument()** # <- maybe need change this ? Time=doc.GetTime() Frame=Time.GetFrame(doc.GetFps()) print Frame if Frame==0:return c4d.Ocube `` if Frame==10:return c4d.Ocone ` if Frame==20:r:return c4d.OSphere return None
if Frame==20:r
the problem is here ``doc=documents.GetActiveDocument() dosen't work correct in render i think i need something like this to use **ObjectData. AddToExecution( _self_ , _op_ , _list_ ) ObjectData.Execute`( self , op , doc , bt , priority , flags )** here i have doc
but i don't know how to use this
any idea ?
Thank you
On 03/01/2011 at 04:05, xxxxxxxx wrote:
Hi and Welcome to PluginCafe.com. Please try this:
doc=op.GetDocument()
Cheers, Sebastian
On 03/01/2011 at 04:28, xxxxxxxx wrote:
Thank you Very Much Sebastian now understand what i did wrong doc=op.GetDocument() -> so this Returns the document where the object is stored in . and work fine now !
Thank you again !!!!
On 03/01/2011 at 04:38, xxxxxxxx wrote:
Just want to add that GetActiveDocument returns only the opened editable document. The renderer, except viewport rendering, uses a clone of this document. This is why GetActiveDocument will return the wrong document during rendering.
On 03/01/2011 at 05:03, xxxxxxxx wrote:
Hi just i want to ask something i found now whe i use
doc1=documents.GetActiveDocument() doc2=op.GetDocument() print doc1.GetFps() print doc2.GetFps()
the doc1 work fine but if i use doc2 like op.GetDocument() say error
i do something wrong ? i use in
def Init(self, op) : because i want to install my vaules and one is c4d.BaseTime
On 03/01/2011 at 15:52, xxxxxxxx wrote:
In Init(..) the object is not in the document yet.
obj=c4d.BaseObject(YOUR_PLUGIN_ID) #internal call of the constructor and Init(..) afterwards doc.InsertObject(obj) #here op is connected with the doc
On 04/01/2011 at 01:55, xxxxxxxx wrote:
ok thank you very much for clear this
