Access object attributes with Python
    On 14/12/2010 at 08:16, xxxxxxxx wrote:
    Cinema 4D Version:   12
    Platform:
    Language(s) :       PYTHON  ;
    Hi all,
    just a simple question: how can I access an object attribute in Python? In Coffee it was something like object#ATTRIBUTE_ID, with the id automatically written by a drag and drop from the attribute's field. Is there something similar in Python?
    Thanks
    Riccardo
    On 14/12/2010 at 08:25, xxxxxxxx wrote:
    Hello cosmodrome,
    You can also drag&drop the attribute in to the python-console.
    To access an example: obj[c4d.PRIM_CUBE_SUBX]=10
    On 14/12/2010 at 08:58, xxxxxxxx wrote:
    Thank you for your answer.
    In fact my problem was more general, because in Coffee the variable "op" is a reference to the object the Coffee tag is applied, whereas in Python - as I just discovered - op is a reference to the tag itself, so I had to write something like:
    obj = op.GetObject()
    obj[c4d.ATTRIBUTE_ID] = 10
    and that way it works :)
    Riccardo
