Reading port information of XPresso node
On 07/12/2010 at 01:34, xxxxxxxx wrote:
Cinema 4D Version: 11.5
Platform:
Hello all,I create my first XPresso node plugin and now I have a problem to read the values from the input ports. I'm using the GvOperatorData.Calculate() function where I ckeck the input ports in a loop:
while (...)
GvPort* gvp=bn->GetInPort( i );And I get also the pointer to every port. But If I try to read the data from the port
gvp->GetBool( &bdata, run )
then I get always FALSE back.
Has someone an idea how I can read an simple bool value from an input port?thanks.
Marky
On 07/12/2010 at 02:55, xxxxxxxx wrote:
Have you seen this thread, maybe it helps? It contains the complete source code of the Result node.
https://plugincafe.maxon.net/topic/4040/3565_creating-new-expresso-result-node
cheers,
Matthias
On 07/12/2010 at 03:53, xxxxxxxx wrote:
oh, thanks a lot. That's what I need.
On 07/12/2010 at 07:54, xxxxxxxx wrote:
do you have also an example for an other node, like the Invert node in the calculation folder?cheers,
Marky
On 13/12/2010 at 07:48, xxxxxxxx wrote:
Here is the complete code of the Math node:
gv_math_operator.h
class GvMathOperator : public GvOperatorData { INSTANCEOF(GvMathOperator,GvOperatorData) private: GvValuesInfo ports; GvDynamicData data; GvValueFlags func; public: GvMathOperator(void); virtual ~GvMathOperator(void); public: virtual Bool iCreateOperator(GvNode *bn); virtual const String GetDetailedText(GvNode *bn); virtual const String GetText(GvNode *bn); virtual const String GetTitle(GvNode *bn); virtual Bool InitCalculation(GvNode *bn, GvCalc *c, GvRun *r); virtual void FreeCalculation(GvNode *bn, GvCalc *c); virtual Bool Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *c); virtual Bool iGetPortDescription(GvNode *bn, GvPortIO port, LONG id, GvPortDescription *pd); virtual Bool GetDDescription(GeListNode *node,Description *description, LONG &flags); virtual Bool SetDParameter(GeListNode *node, const DescID &id,const GeData &t_data,LONG &flags); static NodeData* Alloc(void) { return gNew GvMathOperator; } }; ////////////////////////////////
gv_math_operator.cpp
#include "operators.h" #include "gv_math_operator.h" #include "lib_description.h" #include "gvmath.h" //////////////////////////////// #define NR_OF_FUNCTIONS 5 static LONG title_ids[NR_OF_FUNCTIONS] = { GV_ADD_NODE_TITLE_STRING, GV_SUB_NODE_TITLE_STRING, GV_MUL_NODE_TITLE_STRING, GV_DIV_NODE_TITLE_STRING, GV_MOD_NODE_TITLE_STRING, }; //////////////////////////////// GvMathOperator::GvMathOperator(void) { } GvMathOperator::~GvMathOperator(void) { } //////////////////////////////// Bool GvMathOperator::iCreateOperator(GvNode *bn) { BaseContainer *bc = bn->GetOpContainerInstance(); if (!bc) return FALSE; bc->SetLong(GV_DYNAMIC_DATATYPE,ID_GV_DATA_TYPE_REAL); bc->SetLong(GV_MATH_FUNCTION_ID,GV_ADD_NODE_FUNCTION); return SUPER::iCreateOperator(bn); } const String GvMathOperator::GetDetailedText(GvNode *bn) { return GvGetOperatorDetailedText(this,bn); } const String GvMathOperator::GetText(GvNode *bn) { BaseContainer *bc = bn->GetOpContainerInstance(); String text = GeLoadString(title_ids[bc->GetLong(GV_MATH_FUNCTION_ID)]); GvDataInfo *info = GvGetDataInfo(bn,GV_DYNAMIC_DATATYPE); return info ? text + String(":") + *info->data_handler->GetName(info->data_handler->userdata) : text; } const String GvMathOperator::GetTitle(GvNode *bn) { BaseContainer *bc = bn->GetOpContainerInstance(); LONG func = bc->GetLong(GV_MATH_FUNCTION_ID); return GeLoadString(GV_MATH_NODE_TITLE_STRING) + String(":") + GeLoadString(title_ids[func]); } Bool GvMathOperator::iGetPortDescription(GvNode *bn, GvPortIO port, LONG id, GvPortDescription *pd) { if (!SUPER::iGetPortDescription(bn,port,id,pd)) return FALSE; GvDataInfo *info = GvGetDataInfo(bn,GV_DYNAMIC_DATATYPE); if (!info) return FALSE; switch (id) { case GV_MATH_INPUT: case GV_MATH_OUTPUT: pd->data_id = info->data_handler->data_id; break; } return TRUE; } //////////////////////////////// Bool GvMathOperator::SetDParameter(GeListNode *node, const DescID &id,const GeData &t_data,LONG &flags) { if (!SUPER::SetDParameter(node,id,t_data,flags)) return FALSE; switch (id[0].id) { case GV_DYNAMIC_DATATYPE: { flags |= DESCFLAGS_PARAM_SET; GvNode *bn = (GvNode* )node; if (!GvCheckDataInfo(bn,GV_DYNAMIC_DATATYPE)) return FALSE; if (!bn->ResetPortType(GV_MATH_INPUT)) return FALSE; if (!bn->ResetPortType(GV_MATH_OUTPUT)) return FALSE; } break; } return TRUE; } Bool GvMathOperator::GetDDescription(GeListNode *node,Description *description, LONG &flags) { if (!SUPER::GetDDescription(node,description,flags)) return FALSE; if (flags & DESCFLAGS_DESC_LOADED) { BaseContainer *bc = description->GetParameterI(DescLevel(GV_DYNAMIC_DATATYPE),NULL); if (bc) { BaseContainer types; BaseContainer *b = ((GvNode* )node)->GetOpContainerInstance(); GvValueFlags func = GV_CALC_NOP; switch (b->GetLong(GV_MATH_FUNCTION_ID)) { case GV_ADD_NODE_FUNCTION: func = GV_CALC_ADD; break; case GV_SUB_NODE_FUNCTION: func = GV_CALC_SUB; break; case GV_MUL_NODE_FUNCTION: func = GV_CALC_MUL; break; case GV_DIV_NODE_FUNCTION: func = GV_CALC_DIV; break; case GV_MOD_NODE_FUNCTION: func = GV_CALC_MOD; break; default: return FALSE; break; } if (func != GV_CALC_NOP) { GvGetWorld()->GetDataTypes(types,GV_DATA_OPTIONS_NONE,func); bc->SetData(DESC_CYCLE,types); } } } return TRUE; } //////////////////////////////// static LONG input_ids[] = { GV_MATH_INPUT, 0 }; enum { GV_MATH_INPUT_INDEX }; Bool GvMathOperator::InitCalculation(GvNode *bn, GvCalc *c, GvRun *r) { if (!GvBuildValuesTable(bn,ports,c,r,input_ids)) return FALSE; if (!GvAllocDynamicData(bn,data,c,GV_DYNAMIC_DATATYPE)) return FALSE; BaseContainer *bc = bn->GetOpContainerInstance(); switch (bc->GetLong(GV_MATH_FUNCTION_ID)) { case GV_ADD_NODE_FUNCTION: func = GV_CALC_ADD; break; case GV_SUB_NODE_FUNCTION: func = GV_CALC_SUB; break; case GV_MUL_NODE_FUNCTION: func = GV_CALC_MUL; break; case GV_DIV_NODE_FUNCTION: func = GV_CALC_DIV; break; case GV_MOD_NODE_FUNCTION: func = GV_CALC_MOD; break; default: func = GV_CALC_NOP; break; } return TRUE; } void GvMathOperator::FreeCalculation(GvNode *bn, GvCalc *c) { GvFreeValuesTable(bn,ports); GvFreeDynamicData(data); } Bool GvMathOperator::Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *c) { LONG i, j, n = 0; GvValue *v; v = ports.in_values[GV_MATH_INPUT_INDEX]; if (v) { v->Calculate(bn,GV_PORT_INPUT,r,c,GV_MULTIPLE_PORTS); j = v->NrOfPorts(); for (i = 0; i < j; ++i) { if (n == 0) { if (!v->GetPort(i)->CalculateRawData(data.data,data.data,r,GV_CALC_SET)) return FALSE; } else { if (!v->GetPort(i)->CalculateRawDataRev(data.data,data.data,r,func)) return FALSE; } ++n; } } if (n == 0) GvClearDynamicData(data,r); return ports.out_ports[0]->CopyRawData(data.data,r); } ////////////////////////////////
Please check also the gvmath.* resource files.
cheers,
Matthias
On 22/12/2010 at 06:32, xxxxxxxx wrote:
great, exactly what I need to understand.
thanks a lot.
