On 06/12/2010 at 15:46, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Language(s) : PYTHON ;
--------- I'm trying to setup an aim constraint with python.
I know how to create the tag with :
Tcaconstraint = 1019364 constr = c4d.BaseTag(Tcaconstraint)
and check the 'aim' box with :
constr[c4d.ID_CA_CONSTRAINT_TAG_AIM] = 1
I've worked out how to add link fields with :
constr[c4d.ID_CA_CONSTRAINT_TAG_AIM_TARGET_COUNT] = 1
But I'm stuck at accessing the properties of the links. When I try to use :
constr[c4d.ID_CA_CONSTRAINT_TAG_AIM_AXIS] = 2
to set the axis to Z+, nothing happens. I guess I need to access it by index, because there can be any number of links, but I don't know the syntax. The .H file, which I've used to get this far, mentions containers, so I guess maybe I have to change the properties in a variable and load it in but again, I don't know the syntax.
If anyone could help me with an example of how to add a link, it would be greatly appreciated.
