On 06/12/2010 at 11:10, xxxxxxxx wrote:
--------- Hi All,
I am trying to use COFFEE to scan all the objects in the scene. I want to examine each object's name and if a match, then operate on it. The operation is to Add a TAG to the object if the TAG is not present.
Is this possible in COFFEE node of expresso?
If so, what would the code look like?
On 07/12/2010 at 02:51, xxxxxxxx wrote:
It's quite easy to do with a recursive function call.
Example code browsing through all objects and printing the name of each object.
BrowseScene(op) { while (op) { println(op->GetName()); //prints the object's name BrowseScene(op->GetDown()); //recusive call of BrowseScene op = op->GetNext(); } } main(doc,op) { BrowseScene(doc->GetFirstObject()); }
On 07/12/2010 at 06:17, xxxxxxxx wrote:
Thank you , Matthias.
So how would I make use of this in a COFFEE node? For instance, what if I want to output all the objects into a list so other xpresso nodes can process them?
Is this practical, or is it best to just remain inside the COFFEE node and try to write one massive process?
