On 22/11/2010 at 06:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Windows ; Language(s) : C++ ;
--------- Hi! Can anybody tell me please what I have to do to create a Constraint Tag (PSR)?? Thanks!
On 23/11/2010 at 05:32, xxxxxxxx wrote:
Simple example how to create a CA Constraint tag and add a PSR target.
Bool MenuTest::Execute(BaseDocument *doc) { // constraint object BaseObject *op1 = doc->GetFirstObject(); if (!op1) return FALSE; // target object BaseObject *op2 = op1->GetNext(); if (!op2) return FALSE; // create the tag BaseTag *tag = op1->MakeTag(1019364, NULL); if (!tag) return FALSE; op1->Message(MSG_UPDATE); // enable PSR constraints tag->SetParameter(DescID(ID_CA_CONSTRAINT_TAG_PSR), GeData(TRUE), DESCFLAGS_SET_0); // calls the Add button to add a target DescriptionCommand dc; dc.id = DescID(DescLevel(ID_CA_CONSTRAINT_TAG_PSR_ADD, DTYPE_BUTTON, tag->GetType())); tag->Message(MSG_DESCRIPTION_COMMAND, (void* )&dc); AutoAlloc<BaseLink> link; if (!link) return FALSE; link->SetLink(op2); // sets the link to the target object; target link IDs start with 10001 for the first target, 10002 for the second and so on tag->SetParameter(DescID(10001), GeData(link), DESCFLAGS_SET_0); tag->Message(MSG_UPDATE); EventAdd(); return TRUE; }
On 24/11/2010 at 07:43, xxxxxxxx wrote:
thanks a lot!
