On 13/11/2010 at 00:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I am able to do a drag&drop into my dialog, however I cannot detect that the mouse was released over my field. The BFM_DRAG_FINISHED or the BFM_DRAG_LOST doesn't seem to be correct.
What is the best way of doing this? I am using Cinema 4D 11.5
oDialog::Message(msg) { if (msg->GetId() == BFM_DRAGRECEIVE) { println ("Drag message ontvangen."); if (CheckDropArea(DRAGDROP, msg, TRUE, TRUE)) { var string; var obj=GetDragObject(msg); if (instanceof(obj,BaseObject)) { string=obj->GetName(); SetString (DRAGDROP, string); println ("The mouse is in DRAGDROP and dropped.", string); // The mouse is in drop area. } else println ("Wrong type was dragged."); //if (msg->GetData(BFM_DRAG_FINISHED)) println ("Finished."); // does not work??? } // end mouse is in drop area.
if (msg->GetData(BFM_DRAG_LOST)) // never seem to get here??? { println ("lost..........."); // We are no longer the target of the drag operation. // Remove or reset any help text/lines. } } // end if (msg->GetId() == BFM_DRAGRECEIVE) return super::Message(msg); } // end Message
