Create my own Xpresso node
    On 11/11/2010 at 03:03, xxxxxxxx wrote:
    Cinema 4D Version:   11.5
    Platform:   Windows  ;
    i like to create my own Xpresso node as an plugin, but I don't know which plugin type I must using?
    NodeData ?
    regards
    Markus
    On 11/11/2010 at 03:39, xxxxxxxx wrote:
    XPresso node plugins are derived from GvOperatorData. Unfortunatly there is no SDK example of XPresso nodes but there is some information and examples in the forum.
    cheers,
    Matthias
    On 11/11/2010 at 07:11, xxxxxxxx wrote:
    thanks,
    ok I'm create my node data and register it with RegisterNodePlugin(....).
    But where appears this new node? In which menu can I find it. I thought, that I find it in the X-Pool.
    On 11/11/2010 at 07:29, xxxxxxxx wrote:
    Instead of RegisterNodePlugin use GvRegisterOperatorPlugin which also takes the group ID as argument where you want to make your node available.
    For instance: GvRegisterOperatorPlugin(..., ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, ID_GV_IGNORE_OWNER, ...)
    Cheers, Sebastian
    On 12/11/2010 at 00:01, xxxxxxxx wrote:
    find, it works.
    thanks a lot.
    Cheers, Markus
    On 12/11/2010 at 04:18, xxxxxxxx wrote:
    hi again,
    now I try to add more and more functions. Also the port menu with the FillPortsMenu(..) function.
    I see the new menu entry, if I select the corner of my node with the mouse. But if I select one of this menu entries, i get a cinema4d alert from gv_nodedata.cpp file. Also the debugger stopped with an message "C4D has triggered a breakpoint". I don't know what's wrong. Has someone an idea?
    cheers, Markus
