Initialising Gradient
On 08/11/2010 at 07:31, xxxxxxxx wrote:
Cinema 4D Version:   12
in pre R12 I used to initialise a gradient element like this in a shader::Init() :
   AutoAlloc<Gradient> gradient1;
  if (!gradient1) return FALSE;
  GradientKnot k1;
  k1.col =Vector(1.0,1.0,1.0);
  k1.pos =1.0;
  gradient1->InsertKnot(k1);
  k1.col =Vector(0.0,0.0,0.0);
  k1.pos =0.0;
  gradient1->SetData(GRADIENT_INTERPOLATION,GRADIENT_INTERPOLATION_LINEAR);
     data->SetData(DPIT_SMOKE_NOISE_GRADIENT,GeData(CUSTOMDATATYPE_GRADIENT,gradient1));
In R12 however this doesn´t work anymore (the gradient is initialised completely white). How does it work in R12?
Thanks
On 08/11/2010 at 07:50, xxxxxxxx wrote:
Ok, it seems the gradient IS correctly initialised but it anyway shows all the knots as white. And as soon as you touch the knots it indeed gets white. So is this a bug or am I doing anything wrong? It worked just fine before R12. 😕
On 08/11/2010 at 07:56, xxxxxxxx wrote:
Hm, looks ok to me.
This is the code from the SDKGradient example:
Bool SDKGradientClass::Init(GeListNode *node)
  BaseContainer *data = ((BaseShader* )node)->GetDataInstance();
  AutoAlloc<Gradient> gradient;
  if (!gradient) return FALSE;
  GradientKnot k1,k2;
  k1.col =Vector(0.0,0.0,1.0);
  k1.pos =0.0;
  k2.col =1.0;
  k2.pos =1.0;
  gradient->InsertKnot(k1);
  gradient->InsertKnot(k2);
  data->SetData(SDKGRADIENTSHADER_COLOR,GeData(CUSTOMDATATYPE_GRADIENT,gradient));
  data->SetBool(SDKGRADIENTSHADER_CYCLE,FALSE);
  data->SetLong(SDKGRADIENTSHADER_MODE,0);
  data->SetReal(SDKGRADIENTSHADER_ANGLE,0.0);
  data->SetReal(SDKGRADIENTSHADER_TURBULENCE,0.0);
  data->SetReal(SDKGRADIENTSHADER_OCTAVES,5.0);
  data->SetReal(SDKGRADIENTSHADER_SCALE,1.0);
  data->SetReal(SDKGRADIENTSHADER_FREQ,1.0);
  data->SetBool(SDKGRADIENTSHADER_ABSOLUTE,FALSE);
  return TRUE;
cheers,
Matthias
On 08/11/2010 at 08:05, xxxxxxxx wrote:
yeah, I also found this in the sdk and it seems to work in the sdk example. Any idea what might be the problem? It´s the same for all my gradients so it seems strange. I also looked up the resources and beside having the ICC_BASEDOCUMENT; flag (which I added now to mine too but didn´t change anything) there´s nothing new to it.
Also in InitRender I call InitRender(irs) as in the sdk example but this doesn´t seem to change anything (well, how should it, it´s just the new call to pass irs). Could it be because I am in a MaterialData and not a ShaderData? Because in my ChannelShaders it works just fine!
On 08/11/2010 at 08:10, xxxxxxxx wrote:
hmm, no. I just added it to the simplematerial example and it works there. Argh, what could it be? I mean it worked before just fine and now in R12 it doesn´t. Did anything concerning resources convention change or similar? I am also using a custom material preview, could that be it? Also I am using the Obaselist for the material manager and the gradient is in a different GROUP.
On 08/11/2010 at 08:28, xxxxxxxx wrote:
Ah! It happens with the ALPHA flag only! This also happens in the simplematerial. So is this to be considered a bug?
On 08/11/2010 at 08:31, xxxxxxxx wrote:
Here is the changed code I used for testing in simplematerial:
class SimpleMaterial : public MaterialData
  INSTANCEOF(SimpleMaterial,MaterialData)
  private:
      Vector color;
      Gradient* grad;
  public:
      virtual Bool Init        (GeListNode *node);
      virtual    void CalcSurface            (BaseMaterial *mat, VolumeData *vd);
      virtual    INITRENDERRESULT InitRender(BaseMaterial *mat, const InitRenderStruct &irs);
      virtual    void FreeRender(BaseMaterial *mat)
          if(grad) grad->FreeRender();
  virtual Bool GetDParameter(GeListNode *node, const DescID &id,GeData &t_data,DESCFLAGS_GET &flags);
  virtual Bool SetDParameter(GeListNode *node, const DescID &id,const GeData &t_data,DESCFLAGS_SET &flags);
  virtual Bool Message(GeListNode* node, LONG type, void* data);
  virtual Bool CopyTo(NodeData *dest, GeListNode *snode, GeListNode *dnode, COPYFLAGS flags, AliasTrans *trn);
      static NodeData *Alloc(void) { return gNew SimpleMaterial; }
  LONG updatecount;
Bool SimpleMaterial::Init(GeListNode *node)
  BaseContainer *data=((BaseMaterial* )node)->GetDataInstance();
  data->SetVector(SIMPLEMATERIAL_COLOR,1.0);
  updatecount = 0;
  GeData previewData(CUSTOMDATATYPE_MATPREVIEW, DEFAULTVALUE);
  MaterialPreviewData* preview = (MaterialPreviewData* )previewData.GetCustomDataType(CUSTOMDATATYPE_MATPREVIEW);
  if (!preview)
  return FALSE;
  data->SetData(SIMPLEMATERIAL_MAT_PREVIEW, previewData);
  GradientKnot k1,k2;
  k1.pos =0.0;
  k2.col =1.0;
  k2.pos =1.0;
  data->SetData(SIMPLEMATERIAL_COLORG,GeData(CUSTOMDATATYPE_GRADIENT,gradient));
  return TRUE;
INITRENDERRESULT SimpleMaterial::InitRender(BaseMaterial *mat, const InitRenderStruct &irs)
  BaseContainer *data=mat->GetDataInstance();
  color = data->GetVector(SIMPLEMATERIAL_COLOR);
  grad     = (Gradient* )data->GetCustomDataType(SIMPLEMATERIAL_COLORG,CUSTOMDATATYPE_GRADIENT);
  if (!grad || !grad->InitRender(irs)) return INITRENDERRESULT_OUTOFMEMORY;
  return INITRENDERRESULT_OK;
.h
enum
  ID_TESTGROUP = 3000,
  SIMPLEMATERIAL_COLOR        = 1000,
  SIMPLEMATERIAL_MAT_PREVIEW  = 1001,
.res
  GROUP ID_MATERIALPROPERTIES
      DEFAULT 1;
      COLOR     SIMPLEMATERIAL_COLOR {}
  GROUP ID_TESTGROUP
      GRADIENT SIMPLEMATERIAL_COLORG {ALPHA;}
.str
  SIMPLEMATERIAL_COLOR    "Color";
  SIMPLEMATERIAL_COLORG "Testgradient";
  ID_TESTGROUP "Test";
On 08/02/2011 at 02:42, xxxxxxxx wrote:
Alpha gradients have to be set their mode before any knot is set.
Example:
  //ust be set before any knot is set
  gradient->SetData(GRADIENT_MODE, GeData(GRADIENTMODE_ALPHA));
  GradientKnot k1,k2;
  k1.pos =0.0;
  k2.col =1.0;
  k2.pos =1.0;
  return TRUE;
I will update the docs accordingly.
cheers,
Matthias
On 08/02/2011 at 02:54, xxxxxxxx wrote:
thank you Matthias. I confirm it's working fine now. super.
