Node Crash
On 31/10/2010 at 08:52, xxxxxxxx wrote:
Cinema 4D Version:   11.5
Language(s) :     C++  ;  XPRESSO  ;
I have a node with an inport that is crashing and I don´t know why.
Here is some code:
EditNode : public GvOperatorData
  // Defines super
  INSTANCEOF(EditNode, GvOperatorData)
public:
  virtual Bool AddToCalculationTable(GvNode *bn, GvRun *r);
  virtual Bool iCreateOperator(GvNode *bn);
  Bool InitCalculation(GvNode *bn, GvCalc *c, GvRun *r)
      return GvBuildInValuesTable(bn, ports, c, r, input_ids);
  void FreeCalculation(GvNode *bn, GvCalc *c)
      GvFreeValuesTable(bn, ports);
  Bool Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc);
  static NodeData* Alloc(void) { return gNew EditNode; }
private:
  GvValuesInfo ports;
Bool EditNode::iCreateOperator(GvNode *bn)
  BaseContainer* data = bn->GetOpContainerInstance();
  data->SetLong(EDIT_INDEX,0);
  if (!data) return FALSE;
  return SUPER::iCreateOperator(bn);
Bool EditNode::AddToCalculationTable(GvNode *bn, GvRun *r)
  return (r) && (r->AddNodeToCalculationTable(bn));
Bool EditNode::Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc)
  BaseContainer *data = bn->GetOpContainerInstance();
  BaseDocument* doc = bn->GetNodeMaster()->GetDocument();
  if (!doc) return FALSE;
  GvValue* vinport    = ports.in_values[EDIT_INDEX]; if (!vinport) return FALSE;
  if (!vinport->Calculate(bn, GV_PORT_INPUT, run, calc, 0)) return FALSE; //<- HERE IT CRASHES!
Even when it is the only node in the xpresso editor (I have not set NEEDCONNECTION in the resources) it crashes at the shown function call. Any idea why it crashes? the shown pointers are all valid, I checked in debug mode.
This is in my resources in the ports group:
GROUP ID_GVPORTS
  LONG    EDIT_INDEX    {INPORT; STATICPORT; CREATEPORT;}
This happens with all my according nodes so it´s quite grave and I´d need to fix it.
Thanks in advance!
Thanks in advance
On 03/11/2010 at 04:42, xxxxxxxx wrote:
Hm, I can't find anything wrong with your code. There is one small thing (nothing to do with your problem) the check for data in EditNode::iCreateOperator should be done a line earlier.
cheers,
Matthias
On 03/11/2010 at 05:25, xxxxxxxx wrote:
Hmm, thanks first of all matthias but it anyway crashes (the data was just a mistake got in when I altered the code here for the cafe). Did you try to run that code? I have prepared a ready to compile zip project containing it which also crashes for me. I send it to you via pm.
To make sure it´s not any mistake of other objects of mine linked to it I took everything out. So I apparently still must have something wrong in there.
During debugging it jumps into the Calculate function and then crashes in there. 😕
On 03/11/2010 at 06:42, xxxxxxxx wrote:
I will look into it.
cheers,
Matthias
On 03/11/2010 at 09:15, xxxxxxxx wrote:
After looking more into your code I think the problem is this line
GvValue* vinport = ports.in_values[FLIPEDIT_INDEX]; if (!vinport) return FALSE;
It should be
GvValue* vinport = ports.in_values[0]; if (!vinport) return FALSE;
GvValuesInfo::in_values is an array to sets of input arrays. The input ports of a set of input ports can be iterated through GvValue::NrOfPorts, GvValue::GetPort.
For instance this is the code of the Math node's Calculate method.
Bool GvMathOperator::Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *c)
  LONG i, j, n = 0; GvValue *v;
  v = ports.in_values[GV_MATH_INPUT_INDEX]; //GV_MATH_INPUT_INDEX is 0
  if (v)
      v->Calculate(bn,GV_PORT_INPUT,r,c,GV_MULTIPLE_PORTS);
      j = v->NrOfPorts();
      for (i = 0; i < j; ++i)
          if (n == 0)
              if (!v->GetPort(i)->CalculateRawData(data.data,data.data,r,GV_CALC_SET)) return FALSE;
          else
              if (!v->GetPort(i)->CalculateRawDataRev(data.data,data.data,r,func)) return FALSE;
          ++n;
  if (n == 0) GvClearDynamicData(data,r);
  return ports.out_ports[0]->CopyRawData(data.data,r);
cheers,
Matthias
On 03/11/2010 at 09:35, xxxxxxxx wrote:
Thank you Matthias! I guess I simply haven´t thought about it, but the zero indexing makes sense now of course seeing that in_values is defined as an array. this definetly helped.
