On 23/10/2010 at 15:09, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Windows ; Language(s) : C++ ;
--------- Hello, I am currently trying to get the new preferences working and stripped bobtronic's example from this thread, which works, I get two timeline preferences entires. When I change this to my res-file I get the following error: Unable to open file ...[cinema4d folder]\resource\res\description\prefssolo.res So cinema is looking for it in its own resources instead of my plugin's res-folder. When I put the .res, .h and .str file in the cinema4d res and string paths they are loaded correctly. How do I get cinema to load my plugin prefs from my plugin folder? Thanks in advance.
Boris
On 27/10/2010 at 06:11, xxxxxxxx wrote:
Please wait for the final documentation (which should be ready next week hopefully). It contains a full working example of a preference hook.
On 27/10/2010 at 08:32, xxxxxxxx wrote:
oh, great, thx.
On 24/11/2010 at 17:22, xxxxxxxx wrote:
Originally posted by xxxxxxxx So cinema is looking for it in its own resources instead of my plugin's res-folder.
This has nothing to do with the PrefsDialogObject. I had the same problem once. It turned out that I had removed the part
case C4DPL_INIT_SYS: if (!resource.Init()) return FALSE; // don't start plugin without resource
from the main.cpp's PluginMessage(). Bad idea. Always initialize your ressources. Somehow I am pretty sure you did the same
Cheers, Jack
