On 21/10/2010 at 08:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: R11 Platform: Windows ; Language(s) : C++ ;
--------- Some here may remember the old 'Dark Tree' shader system which was implemented on C4D through a third-party library and a shader plugin. These were great shaders (IMO anyway) but sadly the plugins were never updated for R9 or upwards.
My current project is an attempt to resurrect these and I've almost got the channel shader working, but I've run into a problem with bump. The old shader used the CHANNEL_DIRECTBUMP_EX method and I've got this working for R11. However, this won't work on R11.5+ so I need to switch to the 4-sample bump method with CHANNEL_BUMP_SUPPORT. Below is the relevant section of code from the Output() function:
//get bump value if we are rendering a bump channel if(GET_TEX_CHANNEL(cd->texflag) == CHANNEL_BUMP) { dtrenderstate.point[0] = p.x; dtrenderstate.point[1] = p.y; dtrenderstate.point[2] = p.z; dtrenderstate.evaluateAs = DSdte::DTE_EVAL_BUMP; // convert class to a struct for the C function state = RenderStateToStruct(dtrenderstate); result = DSdte::Evaluate(theSim.bumpdte, &state;); if(cd->vd) { cd->vd->bumpn.x = result.n[0]; cd->vd->bumpn.y = result.n[1]; cd->vd->bumpn.z = result.n[2]; } }
In order to understand what's going on, the system works by loading a number of variables into a 'dtrenderstate' class which is converted into a struct before calling the actual library function, as this is written in C rather than C++. In the code 'p' is the point being evaluated and DSdte::Evaluate is the call to the library function, which returns a vector. For the color channel this is returned as a color, but for bump the code (which is derived from the original plugin code) directly modifies the bump normal in the VolumeData structure.
This works fine when using CHANNEL_DIRECTBUMP_EX but when using CHANNEL_BUMP_SUPPORT the rendered bump looks completely wrong. What I'd like to do is convert this to using the CHANNEL_BUMP_SUPPORT for compatibility with R11.5+, but I can't see how to do it. I've searched here and seen Matthias' example of a turbulence shader, but I still don't understand how to implement that with the values I have to work with.
Does anyone have any comments or suggestions about how to get this to work?
Steve
On 27/10/2010 at 06:08, xxxxxxxx wrote:
In this case wouldn't it be better to output the color coded normals and load the shader into the Normal channel of the material?
On 27/10/2010 at 08:08, xxxxxxxx wrote:
Rather than use the bump channel, you mean? That's an interesting thought, I'll see what happens.
Thank you!
