When scaling fails
    On 12/10/2010 at 16:18, xxxxxxxx wrote:
    Cinema 4D Version:   R10-R12
    Which built-in object types will not respond to changes of their scaling values?  For instance, changing the Scale of a Sweep NURBS has no effect on the results - one must scale the underlying spline objects.  Any others of which to be aware (only generators or such)?
    ETA: This may be related to the fact that they are also Instances. :(
    Thanks!
    On 27/10/2010 at 02:11, xxxxxxxx wrote:
    Sorry I can't confirm. Scaling seems to work fine with all objects I tested. The only exception is the Hair object which does not scale the hair guides.
    cheers,
    Matthias
    On 27/10/2010 at 09:28, xxxxxxxx wrote:
    And I can confirm that it can't be confirmed. :)
    Must have had C4D in some odd configuration because I couldn't get Nulls or Sweep NURBS to scale the results.  Now it seems to be working.  Moving on... ;)
