AddJoint, SetWeight crash
On 12/10/2010 at 00:50, xxxxxxxx wrote:
Cinema 4D Version: R12
Platform: Windows ;
Under what circumstances would AddJoint() from CAWeightTag return -1 for the joint index?
I use the following code after I have allocated and added all joint objects to the document.
All joint object pointers are valid.CAWeightTag* tag = CAWeightTag::Alloc(); for(i=0; i < num_joints; i++) { LONG joint_index = tag->AddJoint( joints[i].ob ); // returns -1 ??? } pPoly->InsertTag( tag, NULL );
Then later, calling tag->SetWeight( joint_index, vindex, weight ); will crash the program from passing -1 as joint_index.
On 12/10/2010 at 02:31, xxxxxxxx wrote:
It seems that you have first to insert the tag before inserting the joints.
little example:
void StepThru(BaseObject *op, CAWeightTag *tag) { while (op && tag) { if (op->GetType() == Ojoint) { tag->AddJoint(op); tag->Message(MSG_UPDATE); } StepThru(op->GetDown(), tag); op = op->GetNext(); } } Bool MenuTest::Execute(BaseDocument *doc) { BaseObject *op = doc->GetActiveObject(); if (!op) return FALSE; CAWeightTag *tag = CAWeightTag::Alloc(); if (!tag) return FALSE; op->InsertTag(tag); op->Message(MSG_UPDATE); EventAdd(); StepThru(doc->GetFirstObject(), (CAWeightTag* )tag); return TRUE; }
cheers,
Matthias
On 12/10/2010 at 10:26, xxxxxxxx wrote:
Great, got it working! Thanks.
