Render camera
On 06/10/2010 at 02:17, xxxxxxxx wrote:
Cinema 4D Version: 11.5/12
Platform: Windows ; Mac OSX ;
Hello all,
i have a problem on my videopost plugin.
i use videopost to export current document and send scene to an external renderer.
i need to export all camera in the scene and "mark" the active camera.
now i am making a recursion in real document and if i find a camera i export it and after i check if is the current render camera with:
if ( mycam == bd->GetSceneCamera(Mydoc)) exporter.setscenecamera(mycam)
where my cam is the BaseObject i am exporting.
but my cam and bd->GetSceneCamera(Mydoc) have alwaise 2 differentpointer, and my plugin don't work :(
why this ?
is the scene camera from basedraw internaly cloned?
if yes is there a way to have a link to original camera object from the doument?thanks in advance
Franz
On 07/10/2010 at 02:07, xxxxxxxx wrote:
From where do you get mycam? Where in the code do you compare the cameras and where do you get the Basedraw from?
In a video post effect you can access the camera through the VolumeData (if it is avaible). VolumeData::GetRayCamera. RayCamera has also a link to the real camera, RayCamera::link.
cheers,
Matthias
On 07/10/2010 at 05:52, xxxxxxxx wrote:
i solved... my mistake i was get the cameras from 2 different documentBets
Franz
