R12 Parameters don't animate
    On 02/10/2010 at 15:57, xxxxxxxx wrote:
    Cinema 4D Version:
    Platform:
    In R11.5 and lower I use scripts to export and import animation to text files
    (ie chan export and import).
    In R12 only the PSR values are keyframed (CallCommand(12410)) correct
    but not object parameters when importing.
    Using "Add Keyframe Selection", keys are set but no animation are set.
    Values are simply not recognized.
    Could this be connected to the pointselection/linkfield issue (no update until Event)?
    Below is the part in the loop that sets FocalLength and Aperture (R11.5 OK, R12 not).
    // asize is the amount of columns in txt file
    // warray is the column used
        if(op->IsInstanceOf(Ocamera) && asize > 7 )
            var apert = op#CAMERAOBJECT_APERTURE / aspect;
               if(format == 0 && warray[7]!=NULL) op#CAMERA_FOCUS = apert/(2*tan(Radians(warray[7])/2)); // chan verticalFOV
               if(format == 1 && warray[7]!=NULL && warray[8]!=NULL)
                     op#CAMERA_FOCUS = (warray[7]);        // chan TG 2.1 Focal Length
                     op#CAMERAOBJECT_APERTURE = warray[8]; // chan TG 2.1 Aperture Width mm
               if(format == 2 && warray[7]!=NULL) op#CAMERA_FOCUS          = (warray[7]); // ASCII Focal Length
               if(format == 2 && warray[8]!=NULL) op#CAMERAOBJECT_APERTURE = (warray[8]); // ASCII Aperture mm
            EventAdd(EVENT_ANIMATE); // <- tried but no go
           op->Message(MSG_UPDATE); // <- tried but no go
        EventAdd();
        CallCommand(12410);//record
        DrawViews(DRAWFLAGS_STATICBREAK);//R12
    Lennart
    On 02/10/2010 at 17:49, xxxxxxxx wrote:
    I also just tried setting the values to the base container of op
    instead of using the # operator, but still no go I'm afraid.
    Lennart
    On 04/10/2010 at 02:27, xxxxxxxx wrote:
    Sorry, I can't confirm.
    This simple test code will record keyframes of a sphere's radius. Of course you have to make the radius a key frame selection before running the script. The Cinema 4D help does say so too.
    var op = doc->GetActiveObject();
    var time = new(BaseTime);
    var i;
    for (i=0; i<10; i++)
      time->SetFrame(i, doc->GetFps());
      doc->SetTime(time);
      doc->AnimateDocument(0);
      EventAdd();
      DrawViews(DRAWFLAGS_FORCEFULLREDRAW);
      op#PRIM_SPHERE_RAD = i*10.0;
      CallCommand(12410);
    **Parameter
    When in this mode, in conjunction with Key-Selections, only the selected parameters will be applied when recording keyframes. This works both in the Autokeying mode as well as when recording keyframes manually (Record Active Objects).**
    cheers,
    Matthias
    On 04/10/2010 at 10:16, xxxxxxxx wrote:
    Thanks Matthias for checking and the example.
    Yes I know that and that is what I do (use KeyFrame Selection)
    As I mentioned, keys -are- set for the camera parameters
    but no correct values are set.
    However, what I found out was:
    First, the DrawViews(DRAWFLAGS_FORCEFULLREDRAW) isn't called
    at the "same" moment as the R11 "DrawViews(DA_STATICBREAK)".
    I need to put the DrawView Command before the Record command
    or I get some very erratic keys (wrong values at wrong time).
    Second,
    In R11, to check a valid value in a column from the txt file I use,
    if(array[n] != NULL)
    In R12 I need to use,
    if(array[n] != NOTOK)
    So far it seems to work as it should.
    Lennart
