On 01/10/2010 at 16:57, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Language(s) : PYTHON ;
--------- Is it possible to go over a frame range and find a channel's value (e.g. position.X's value) at each frame?
On 02/10/2010 at 02:01, xxxxxxxx wrote:
Hi whalerider,
at the bottom of the BaseDocument page in the Python (C4DSDK) documentation there is a piece of code which does what you need. The code contains some comments so I hope this helps.
import c4d from c4d import documents def BrowseDoc(doc) : """ Pass the document you want to run the time through""" ctime = doc.GetTime() #save current time fps = doc.GetFps() #go over frame range in the document start = doc.GetMinTime().GetFrame(fps) #set min time until = doc.GetMaxTime().GetFrame(fps) #set max time for f in xrange(start, until+1) : c4d.StatusSetBar(100*(f-start)/(until-start)) doc.SetTime(c4d.BaseTime(f, fps)) c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK) # here you can read out the position c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED) #update timeline doc.SetTime(ctime) #set time back c4d.EventAdd(c4d.EVENT_ANIMATE) c4d.StatusClear()
Cheers, Sebastian
On 02/10/2010 at 02:55, xxxxxxxx wrote:
Thanks, Sebantian. I had missed the code at the bottom. I had figured out the fps/start/until code, but for the rest I needed help.
On 23/10/2010 at 14:35, xxxxxxxx wrote:
Just a quick comment:
for f in xrange(start, until) :
should be
otherwise the last frame will be skipped.
On 23/10/2010 at 16:26, xxxxxxxx wrote:
Thx! I fixed this in the code snippet.
