On 30/09/2010 at 14:03, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C++ ;
--------- Hi, i have a quick question about coloring objects by using ID_BASEOBJECT_COLOR
i tried both of the following, but none did work. any idea what i am missing?
tempObj->SetParameter(ID_BASEOBJECT_USECOLOR,GeData(ID_BASEOBJECT_USECOLOR_ALWAYS),0); tempObj->SetParameter(ID_BASEOBJECT_COLOR,GeData(Vector(1,0,0)),0);
tempObj->GetDataInstance()->SetLong(ID_BASEOBJECT_USECOLOR,ID_BASEOBJECT_USECOLOR_ALWAYS); tempObj->GetDataInstance()->SetVector(ID_BASEOBJECT_COLOR,Vector(1,0,0));
thanks in advance, cheers, Ello
On 01/10/2010 at 06:39, xxxxxxxx wrote:
is it a problem that i am inside GetVirtualObjects? yes, it seems so, but is there a way to do it in GetVirtualObjects? I dont want to assign materials for achiving this. Any ideas?
cheers, Ello
On 01/10/2010 at 09:04, xxxxxxxx wrote:
what is tempObj? An object that you create inside of GetVirtualObjects? Then it should work I´d assume. Without a context it´s hard to say. Do you return that object in GetVirtualObjects? Then what does the object look like when you convert your plugin object that creates this?
On 01/10/2010 at 09:17, xxxxxxxx wrote:
tempObj is a BaseObject::Alloc(Ocube) and is inserted under a Nullobject. When I convert the plugin, the Cube is there, but no Color is set. I temporarily tried what happens when i insert the Cube directly into the document and the color was set, thats why i assume it doesnt work with virtual objects...
On 01/10/2010 at 10:14, xxxxxxxx wrote:
yeah I can confirm it (just tried with a sphere). Don´t know why it doesn´t work (setting primitive specific settings works just fine) but I see no real reason why it shouldn´t work.
On 01/10/2010 at 14:08, xxxxxxxx wrote:
I'm having something of a similar problem with reading/writing color vectors. I'm doing it as SReal() for each component yet the values are reset to default every time - this despite all other settings being read/written properly. Maxon is boiling my blood at the moment. I can't spend every friggin week fixing these issues in R12 while I'm trying to employ what little free time to write a new commercial plugin. It is being evaporated for these vapid hunts of stupid issues. Grrrr...... ;(
On 05/10/2010 at 05:51, xxxxxxxx wrote:
To set the object's color of child objects of a generator you have to use BaseObject::SetColorProperties and additionally the OBJECT_USECACHECOLOR flag has to be set during plugin registration.
here some example code:
BaseObject *RoundedTube::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh) { BaseObject *ret = NULL; Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA); if (!dirty) return op->GetCache(hh); ret = BaseObject::Alloc(Ocube); if (!ret) return NULL; ObjectColorProperties prop; prop.usecolor = ID_BASEOBJECT_USECOLOR_AUTOMATIC; prop.color = Vector(1.0,0.0,0.0); prop.xray = FALSE; ret->SetColorProperties(&prop); return ret; } // be sure to use a unique ID obtained from www.plugincafe.com #define ID_ROUNDEDTUBEOBJECT 1001157 Bool RegisterRoundedTube(void) { return RegisterObjectPlugin(ID_ROUNDEDTUBEOBJECT,GeLoadString(IDS_ROUNDED_TUBE),OBJECT_GENERATOR|OBJECT_USECACHECOLOR,RoundedTube::Alloc,"Oroundedtube",AutoBitmap("roundedtube.tif"),0); }
On 05/10/2010 at 06:31, xxxxxxxx wrote:
thank you very much matthias, i'll try that
cheers, ello
On 05/10/2010 at 07:03, xxxxxxxx wrote:
thanks matthias. Could you additionally explain why this is necessary and doesn´t work by changing the container values? I just would like to understand the reason for this procedure. thank you!
