On 08/09/2010 at 02:25, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- Hello All.... i can compile but can't run melange render connection example ... any sugestion ?
On 08/09/2010 at 08:47, xxxxxxxx wrote:
Hello Franz I understood it(no docs, but in source code), you need: 1. "Locate..."(menu) CINEMA 4D app as server 2. "Generate..." It render this or should convert(?) c4d to melage-format scene by console app
On 08/09/2010 at 08:53, xxxxxxxx wrote:
hello, thanks but unfortunatly this don't work form me. i select cinema 4d executable but render don't start. i have enabled the scene file writing: scene file is created but Startrender return alleaide false all the best Franz
On 08/09/2010 at 09:10, xxxxxxxx wrote:
Strange, all works. I complied at windows xp sp3(32bit).
On 08/09/2010 at 09:11, xxxxxxxx wrote:
i am on vista 64 ... can be this ? Franz
On 08/09/2010 at 09:18, xxxxxxxx wrote:
Sorry, i don't know. Not tested yet
Franz, hm, you want to integrate thea-rt?
On 08/09/2010 at 09:31, xxxxxxxx wrote:
no... is for another project Franz
On 08/09/2010 at 09:50, xxxxxxxx wrote:
Are you use all 64-bit app-s(compiled + c4d 64-bit too)? Sorry for such silly question.
On 09/09/2010 at 04:48, xxxxxxxx wrote:
After choosing "Locate and Start Render Server..." the Windows Firewall should pop up and ask you if want to give access to CINEMA 4D. If this doesn't happen please check your Windows Firewall settings.
On 14/09/2010 at 06:05, xxxxxxxx wrote:
ok solved .... with a litte cleaning of visual studio option Franz
