R12 SDK compile Errors
On 04/09/2010 at 12:05, xxxxxxxx wrote:
Cinema 4D Version:   R12
Platform:      Mac OSX  ;
Howdy,
I'm getting 2 compile errors when trying to compile the R12 SDK from the demo:
/Developer/usr/bin/libtool filed with exit code 1
... and:
/Developer/usr/bin/g++-4.2 failed with exit code 1
I'm on a 2Ghz intel core duo Macbook pro running MacOSX 10.6.4, using Xcode 3.2.3.
Adios,
Cactus Dan
On 04/09/2010 at 12:25, xxxxxxxx wrote:
Howdy,
OK, never mind. It was a simple folder permissions issue. DOH!
Adios,
Cactus Dan
On 04/09/2010 at 12:31, xxxxxxxx wrote:
Hey Dan,
I recall me having the same problem, yet I dont recall how I solved it...
Can you maybe point out which file permissions you had to change in case anyone else(likely me) runs into this? :)
On 04/09/2010 at 16:54, xxxxxxxx wrote:
Howdy,
I just changed the permisions of the entire Cinema 4D R12 Demo folder, by selecting it, and in the Get Info dialog, change the permission to Read & Write, and then selecting "Apply to enclosed items..." from the popup menu at the bottom of the info dialog.
Adios
Cactus Dan
On 04/09/2010 at 19:20, xxxxxxxx wrote:
Down with permissions! :zipper_mouth:
On 06/09/2010 at 01:35, xxxxxxxx wrote:
Yeah, I also had this, some months ago ;-)
Permissions, of course.
On 06/09/2010 at 09:12, xxxxxxxx wrote:
We'll fix this with one of the next online updates.
Right now on the Mac permissions for the folders 'api_lib' and 'cinema4dsdk' need to be manually corrected.
