On 02/08/2010 at 02:22, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5 Platform: Language(s) : C++ ;
--------- Hi,
does anybody know how to use the ViewportHUD class? I couldn't find any info at all.
What i want to do is to draw a string in the viewport during the mouse loop of a tool plugin - exactly like the move/scale/rotate tools do it.
I tried the following:
// in MouseInput viewportHud = ViewportHUD::Alloc() viewportHud->BeginGroup(); ViewportHUDControl* ctrl = viewportHud->AddControl(HUDCONTROL_TYPE_STATIC, doc, bd, NULL, DescID(10000), BaseContainer(), GeData("Hallo!"), DA_STRING); ctrl->SetTopLeft(500, 500); viewportHud->EndGroup();
// in Draw viewportHud->DrawHUD(doc, NULL, doc->GetFps(), bd, HUDCONTROL_DFLAGS_NAME | HUDCONTROL_DFLAGS_FRAME);
this code draws nothing, and DrawHUD returns False
On 02/08/2010 at 05:37, xxxxxxxx wrote:
Hi Michael,
I think it´s not working. At least I never got it working and if I remember correctly someone (guess it was Mikael back then) told me that it´s not possible to draw custom elements in the c4d HUD. Although I am not sure if that still applies but as it´s not working for you either it seems to be still valid.
Instead use a GeClipMap and draw into it, then let it be drawn with DrawTexture instead. That works fine for me and I use it in my tree tool too, so that works for sure.
HTH
On 02/08/2010 at 05:56, xxxxxxxx wrote:
Thanks for the info at least
I think i will use the workaround with the GeClipMap then.
best regards, Michael
On 04/08/2010 at 03:52, xxxxxxxx wrote:
The classes and functions within lib_viewport.h are currently private and not meant for plugin development.
