On 15/07/2010 at 07:25, xxxxxxxx wrote:
--------- Hi all,
I've just started a basic SceneHookData plugin. I want to start a timer when the defaut scene is set dans then write a message each seconds (interval of the timer).
My code is quite simple, in the InitSceneHook method I :
In the method that is called every seconds I show another MessageDialog("Timer")
I work with the demo version of C4D and there is a window that shows up at the beginning. When I run the demo this windows shows up then the "Init" message and the "Timer" message, every seconds. So it works.
The problem is when I close the demo window, the defaut 3D scene shows up and my Timer is stopped... Could you guys tell me what is wrong with my code ?
On 19/07/2010 at 01:20, xxxxxxxx wrote:
I am sorry, without seeing your code it's hard to tell.
On 19/07/2010 at 11:21, xxxxxxxx wrote:
From what I understand, the init of a scenehook isn't called that frequently (just a few times when the scene is loaded).
If you need a timer, I'd use a MessageData and its built in GetTimer function.
-kvb
