On 05/07/2010 at 19:58, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Mac OSX ; Language(s) : C++ ;
--------- Hey all,
I'm building a combo plugin that includes an object, a tag, and a scenehook. There are some global settings associated with the scenehook that I want to be available for the user to alter if necessary.
So, I was wondering how I could get AM parameters for the hook, but it's not something that's "selectable" like an object or a tag so there's no way to display it in the AM. Then there's a dialog, but I don't feel like going that route. Then I remembered the new document mode in the AM in R11.5 and wondered if I could create my own mode and tie it to my hook.
A quick look through the sdk, and I find lib_activeobjectmanager. Woohoo, it looks like I can create my own AM mode, and it's available all the way back to R10, perfect:D But it seems like it's a bit of a different beast than most of the other stuff I've seen in the SDK, so I thought I'd ask a couple of questions before diving in:)
1.It looks like a class, but it's categorized as a "global", so is there any special way to deal with it? (ducks for cover in case that's a stupid noob question).
2. It almost seems like it's designed for scenehooks... Like, it is the quintessential answer to my overall problem of adding parameters to a scenehook plugin. Is that correct? The function to register a new mode has a variable for a MESSAGEHOOK *hook, is that where I put my scenehook plugin to tie that mode to my scenehook? And if so, how do I handle the description resource in this case?
thanks!
-kvb
On 07/07/2010 at 03:03, xxxxxxxx wrote:
Since R11.5 you can set the PLUGINFLAG_SCENEHOOK_SUPPORT_DOCUMENT_DESCRIPTION flag when you register the scene hook. This will cause the scene hook to appear in the document settings, just like the MoDynamics global settings for instance.
Here is a simple example:
#include "c4d.h" #include "c4d_symbols.h" #include "smyscenehook.h" class MySceneHook : public SceneHookData { public: static NodeData *Alloc(void) { return gNew MySceneHook; } }; // be sure to use a unique ID obtained from www.plugincafe.com #define ID_MYSCENEHOOK 1025181 Bool RegisterMySceneHook(void) { return RegisterSceneHookPlugin(ID_MYSCENEHOOK,GeLoadString(IDS_MYSCENEHOOK),PLUGINFLAG_SCENEHOOK_SUPPORT_DOCUMENT_DESCRIPTION,MySceneHook::Alloc,EXECUTION_EXPRESSION,0,NULL); }
You can use standard description resource files, just remember to register the scene hook's description files.
Bool PluginMessage(LONG id, void *data) { ... switch (id) { case C4DPL_INIT_SYS: if (!resource.Init()) return FALSE; // don't start plugin without resource if (!RegisterDescription(ID_MYSCENEHOOK, "Smyscenehook", NULL)) return FALSE; return TRUE; ... }
On 07/07/2010 at 12:20, xxxxxxxx wrote:
Thanks Matthias,
But what about all the pre-R11.5 versions of my plugin? I need a solution that will work for R10+. Does that mean I can't create my own AM mode for use with my plugin in pre-11.5 versions of c4d?
thanks, kvb
On 08/07/2010 at 02:48, xxxxxxxx wrote:
If you want to create a new AM mode you have to register it first. The best place to do this is probably C4DPL_STARTACTIVITY because all plugins have been already registered at this point. You have to pass a function pointer for a message hook to ActiveObjectManager_RegisterMode(). In this message hook you can pass the scene hook over to the AM.
Here is some sample code for the AM mode registration, this goes into the main.cpp.
#define ID_MYSCENEHOOK 1025181 #define ID_SCENEHOOKMODE 1025002 GeData SceneHookMessageHook(const BaseContainer &msg, void *data) { switch (msg.GetId()) { case AOM_MSG_ISENABLED: return TRUE; case AOM_MSG_GETATOMLIST: { BaseDocument *doc = GetActiveDocument(); if (!doc) break; PluginSceneHook *sh = doc->FindSceneHook(ID_MYSCENEHOOK); if (!sh) break; ((AtomArray* )data)->Append(sh); return TRUE; } break; } return FALSE; } Bool PluginMessage(LONG id, void *data) { switch (id) { ... case C4DPL_STARTACTIVITY: if (!ActiveObjectManager_RegisterMode((ACTIVEOBJECTMODE)ID_SCENEHOOKMODE, "Scene Hook", SceneHookMessageHook)) return FALSE; return TRUE; ... } return FALSE; }
This should work from R10.x up to 11.5x.
On 08/07/2010 at 19:45, xxxxxxxx wrote:
thanks Matthias:D
On 17/10/2010 at 20:39, xxxxxxxx wrote:
If I may, I have a follow-up question regarding this:
How do I then give this new AM mode an icon?
On 18/10/2010 at 02:55, xxxxxxxx wrote:
You can change the icon by waiting for the MSG_GETCUSTOMICON message. Fill the passed GetCustomIconData structure with your own icon.
On 18/10/2010 at 05:35, xxxxxxxx wrote:
Thanks (yet again) Matthias:) Working perfectly:)
btw... you should have a donate button on your site... I just went to go click it if it existed... but it didn't:(
