On 15/06/2010 at 00:43, xxxxxxxx wrote:
--------- Hello,
i like to read the size of an texture from a material which assigned to an base object. I do this with the PluginShader.
PluginShader *shd = (PluginShader* )matdata->GetLink(MATERIAL_COLOR_SHADER, GetActiveDocument() , Xbitmap);
BaseBitmap *pbb = shd->GetBitmap(); if (pbb) { lx = pbb->GetBw(); ly = pbb->GetBh(); }
But i get always an NULL pointer for the base bitmap?? Has someone an idea?
On 15/06/2010 at 01:08, xxxxxxxx wrote:
You have to make sure to call GetBitmap() within a pair of InitRender()/FreeRender() calls. If there is no InitRenderStruct avaible you can create a dummy structure on the stack.
here an example:
Bool MenuTest::Execute(BaseDocument *doc) { BaseMaterial *mat = doc->GetActiveMaterial(); if (!mat) return FALSE; BaseContainer *data = mat->GetDataInstance(); PluginShader *shd = (PluginShader* )data->GetLink(MATERIAL_COLOR_SHADER, doc, Xbitmap); if (!shd) return FALSE; InitRenderStruct is; is.version = GetC4DVersion(); is.time = doc->GetTime(); is.fps = doc->GetFps(); Filename docpath = doc->GetDocumentPath(); is.docpath = &docpath; String matname = mat->GetName(); is.matname = &matname; is.errorlist = NULL; is.vd = NULL; is.doc = doc; is.thread = NULL; is.flags = INITRENDERFLAG_TEXTURES; shd->InitRender(&is); BaseBitmap *bmp = shd->GetBitmap(); if (!bmp) return FALSE; GePrint(LongToString(bmp->GetBw())); GePrint(LongToString(bmp->GetBh())); shd->FreeRender(); return TRUE; }
On 15/06/2010 at 01:35, xxxxxxxx wrote:
i see, create it works thanks a lot
