On 13/06/2010 at 07:49, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.5+ Platform: Windows ; Language(s) :
--------- Howdy,
Well, I have a crash problem on Windows in R10.5, R11 and R11.5 with a plugin that is compiled in R10.111. It doesn't crash on Mac OS when running the R10.1 compiled plugin in R10.5+ versions.
I think I've isolated the source of the problem to be CTrack::GetCurve().
If I comment out the call:
CCurve *crv = track->GetCurve();
... then it doesn't crash in R10.5+ on Windows with the R10.111 compiled plugin.
Is the Windows crash happening because in R10.5, CTrack::GetCurve() had a second parameter added? And why is it not crashing on Mac OS? Is there a compiler setting or something that I can do on the Windows side that will prevent that crash, other than just recompiling the plugin in R10.5? I've already recompiled the plugin in R11, but I was trying to keep it simple by only having R9, R10 and R11 versions.
Adios, Cactus Dan
On 14/06/2010 at 02:00, xxxxxxxx wrote:
It's a known problem. Plugins compiled with 10.111 will crash when using GetCurve().
See these threads:
https://plugincafe.maxon.net/topic/3860/3316_crash-when-creating-keyframes
https://plugincafe.maxon.net/topic/3851/3304_ctrackgetcurve-in-105-crashes
On 14/06/2010 at 06:16, xxxxxxxx wrote:
Howdy,
Thanks for the links. I did a search for GetCurve, but somehow overlooked those 2 threads.
I'll try Frank's solution of turning off "Global Optimization", but if my beta testers say it still crashes, is there any way I can get a copy of the R10.5 demo to do a separate compile? I'm still on R10.111 and I've only downloaded the R11 and R11.5 demos for compiling and testing.
Doing a google search for the R10.5 demo only seems to list questionable websites.
On 14/06/2010 at 06:44, xxxxxxxx wrote:
I send you a PM.
