Noise Functions
On 05/06/2010 at 13:01, xxxxxxxx wrote:
hm.. did you set the parameters? i guess its some trial and error now, since i dont know why it crashes.
On 05/06/2010 at 13:03, xxxxxxxx wrote:
this is how I am attempting to subdivide
but it keeps crashing
		if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE))  //If HyperNURBS is checked
		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
		else
		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE);
		mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
	    mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE));
	//Subdivision Command
	SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
On 05/06/2010 at 13:04, xxxxxxxx wrote:
MAX_ANGLE is equal to pi   and subAMount is a real that the user can adjust.   :)
On 05/06/2010 at 13:11, xxxxxxxx wrote:
try catching the crash with
if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat))
GePrint("done");
else
GePrint("failed");
just to be on the safe side..
On 05/06/2010 at 13:44, xxxxxxxx wrote:
Here's my subdivision code now...
Still crashing.
//SUBDIVISION
		Real subAmount;
		subAmount = mcd2.bc->GetLong(SPACEROCK_SUBDIVISIONS);
		mcd2.mode = MODIFY_ALL;
		mcd2.doc = hh->GetDocument();
		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
			GePrint("done");
			mcd2.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
			mcd2.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
			mcd2.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
			SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2);
		else
			GePrint("failed");
Any thoughts?
On 05/06/2010 at 13:55, xxxxxxxx wrote:
hey, dont call SendModelingCommand twice.. its already called in the if condition!
On 05/06/2010 at 14:06, xxxxxxxx wrote:
well.. that was a good thought and a good catch but unfortunately it's still crashing .. this one is a bit of a thorn today.  LOL
On 05/06/2010 at 14:14, xxxxxxxx wrote:
another thing could be worth a try, to set the Parameters for an extra BaseContainer like i did it in my example:
BaseContainer bc;
          bc.SetReal(MDATA_OPTIMIZE_TOLERANCE, tolerance);
          bc.SetReal(MDATA_OPTIMIZE_POINTS, TRUE);
          bc.SetReal(MDATA_OPTIMIZE_POLYGONS, TRUE);
          bc.SetReal(MDATA_OPTIMIZE_UNUSEDPOINTS, TRUE);
          cd.bc = &bc;
and in the if (SendModelingCommand... call "cd.op->Message(MSG_UPDATE, NULL);"
Oh, wait, i didnt see you setting mcd2.op to your object, maybe thats the main problem
On 05/06/2010 at 14:21, xxxxxxxx wrote:
yeah I added that in after I sent the message..  that didn't work.. I'
ll try your other suggestion though.   Thanks,
~Shawn
On 05/06/2010 at 14:31, xxxxxxxx wrote:
alternatively, did you try CallCommand(14047); ?? maybe that works... but i dont know how you set the parameters in this case..
On 05/06/2010 at 15:15, xxxxxxxx wrote:
Awesome..  It works.   Used your different basecontainer suggestion.
//SUBDIVISION
		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
		BaseContainer bc2;
		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
		mcd2.bc = &bc2;
		mcd2.op = polyCube;
			GePrint("done");
		else
			GePrint("failed");
Thanks again.  I'm calling it a night.   Thanks for your help.
On 05/06/2010 at 15:18, xxxxxxxx wrote:
Hi, i did a quick test on subdividing and it works here.. dont ask me why it needs to create the dependency list twice, but if i dont do it, the plugin is updating everytime something changes in the editor even if you turn the camera and such.. if someone can tell my why, i'd be happy.
anyways, here is what is working for me:
#define pluginID 1000001
#define pluginName "testObject"
#include "c4d.h"
#include "c4d_symbols.h"
class testObject : public ObjectData
  INSTANCEOF(testObject,ObjectData);
private:
public:
  virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
  static NodeData *Alloc(void) { return gNew testObject; }
BaseObject *testObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
  BaseDocument* doc = op->GetDocument();
  ModelingCommandData cd;
  Bool dirty;
  BaseObject* main = BaseObject::Alloc(Onull);
  if (!main) goto Error;
  BaseObject* child = op->GetDown();
  if (!child) goto Error;
  op->NewDependenceList();
  op->AddDependence(hh,child);
  dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_MATRIX|DIRTY_DATA|DIRTY_CHILDREN);
  dirty = dirty || !op->CompareDependenceList();
  if (!dirty)
      blDelete(main);
      op->TouchDependenceList();
      return op->GetCache(hh);
  BaseObject* clone = op->GetAndCheckHierarchyClone(hh,child,HCLONE_ASPOLY,&dirty,0,false);//static_cast<PolygonObject*>(child->GetClone(0,0));
  if (clone)
      GePrint ("cloned");
      if (clone->GetType()==Opolygon)
          GePrint("polygonobject detected");
          cd.doc = doc;
          cd.op = clone;
          BaseContainer bc;
          bc.SetBool(MDATA_SUBDIVIDE_HYPER, true);
          bc.SetReal(MDATA_SUBDIVIDE_ANGLE, 90);
          bc.SetLong(MDATA_SUBDIVIDE_SUB, 2);
          cd.bc = &bc;
          if(SendModelingCommand(MCOMMAND_SUBDIVIDE, cd))
              GePrint("modeling command sent: MCOMMAND_SUBDIVIDE");
          else
              GePrint("failed");
          clone->InsertUnderLast(main);
      else
          blDelete(clone);
  return main;
Error:
  if (main) blDelete(main);
  return NULL;
// be sure to use a unique ID obtained from www.plugincafe.com
Bool Register_testObject(void)
  GePrint("- testObject");
  return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,testObject::Alloc,"OtestObject","orgaLine.tif",0);
hope this helps
On 05/06/2010 at 15:19, xxxxxxxx wrote:
*G i was late again :)
