Help with Matrix
On 29/05/2010 at 10:26, xxxxxxxx wrote:
Cinema 4D Version: 11.5
Platform: Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
I'm struggling with dot syntax... Could somebody give me some guidance as to what I'm doing wrong...?I'm just trying to store the cube's X position.
main(doc,op)
var cube=doc->FindObject("Cube");
var cubeX = cube.x;
On 29/05/2010 at 10:49, xxxxxxxx wrote:
You've skipped a step. You must get the position from your object.
var cube = doc->FindObject("Cube"); // this is just what object you want to use var cubeposition = cube->GetPosition(); // This is the local position, vectors x y z. var cubeposX = cubeposition.x; // Her you pick the x vector
Do read the basicsin the 9.5 COFFEE SDK
(Found under "Older SDK" at Support Downloads)
Most of the ideas behind programming is very well described in it.Cheers
Lennart
On 29/05/2010 at 11:05, xxxxxxxx wrote:
I see...
Would you be able to help me with something else...?
I'm trying to keep a null aligned to a spline using an offset specified in a user data field. When I move and rotate the spline, the null doesn't stay aligned because I can't figure out how to input the correct Matrix details. I know this would be simple in Xpresso, but I'm trying to learn COFFEE. I do have the SDK, but it can be difficult to find the answers at times. I would be really grateful for any pointers...
main(doc,op)
var spline=doc->FindObject("Spline");
var point=doc->FindObject("point");var offsetAmount=spline#ID_USERDATA:1;
var offset=spline->GetSplinePoint(offsetAmount,0);point->SetPosition(offset);
On 30/05/2010 at 06:28, xxxxxxxx wrote:
This would be the basics for that. Your position along the spline need to be
converted into Global space.
Note that there is no easy way to get a deformed position.
Also, do check the Init() function in the SDK if you want/need to do any calculations on the spline.Cheers
Lennartmain(doc,op) { var spline = doc->FindObject("Spline"); if(!spline) return; // Not found var Cube = doc->FindObject("Cube"); if(!Cube) return; // Not found var offsetAmount = spline#ID_USERDATA:1; var offset = spline->GetSplinePoint(offsetAmount,0); // The local position along the spline offset = spline->GetMg()->GetMulP(offset);// Get the global offset position var CubeM = Cube->GetMg(); // Get the Cube matrix CubeM->SetV0(offset); // Load new position (your offset) into Cube matrix Cube->SetMg(CubeM); // Reload the edited matrix back to Cube }
On 30/05/2010 at 10:59, xxxxxxxx wrote:
Thanks a lot Lennart, I've been through your help and it's working just as i wanted. You've given me some really good pointers.
Benek
