On 27/05/2010 at 04:47, xxxxxxxx wrote:
--------- Hello,
I try to read the user data from base objects with the BrowseGetNext(..) function. I get back the DescID and a basecontainer with the data. But now i don't know how i can access to this data. Which IDs should i using? I get only the name of the "User Data" with following function.
... while ( pUserData->BrowseGetNext(handle, &id, &data) ) { uid = id[1].id; uType = id[1].dtype; GeData att_name;
att_name = data->GetData(1); }
But i need also the value of it and some furter informations like min and max values or so. Has anyone an idea?
On 28/05/2010 at 01:44, xxxxxxxx wrote:
ok, now i get the additional attibutes like min and max value with the BrowseContainer class. But i don't get the value of the user data. Only the information, that a DA_CUSTOMDATATYPE is delivered.
BrowseContainer brw(data); LONG lid = 0; GeData *att = NULL;
while (brw.GetNext(&lid, &att)) {...
How can i read the data value ???
On 28/05/2010 at 02:12, xxxxxxxx wrote:
What kind of user data type do you want to access?
On 28/05/2010 at 02:17, xxxxxxxx wrote:
hi,
every type. I add the User data in the attribute manager and choosen one type from the list. (Boolean, Integer, Real...). And with a plugin i like to export this data into an external file.
regards Markus
On 28/05/2010 at 02:18, xxxxxxxx wrote:
Maybe you can show me an example for a LONG value ?
On 28/05/2010 at 03:30, xxxxxxxx wrote:
every type...
Ah, ok. That's actually quite simple.
Here is an example how to determine the data type and value of the user data entries:
Bool MenuTest::Execute(BaseDocument *doc) { BaseObject *op = doc->GetActiveObject(); if (!op) return FALSE; DynamicDescription *dd = op->GetDynamicDescription(); if (!dd) return FALSE; void *dhandle = dd->BrowseInit(); DescID id; const BaseContainer *bc = NULL; while (dd->BrowseGetNext(dhandle, &id, &bc)) { GeData data; if (op->GetParameter(id, data, 0)) { //data contains the user data data; the data type of the user data switch (data.GetType()) { case DA_REAL: GePrint("Real: "+RealToString(data.GetReal())); break; case DA_LONG: GePrint("LONG: "+LongToString(data.GetLong())); break; } } } dd->BrowseFree(dhandle); return TRUE; }
On 28/05/2010 at 04:07, xxxxxxxx wrote:
oh i see,
thanks a lot... it works
