On 20/05/2010 at 18:35, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I tried not to post until i researched a lot, and I just can't get this to work ...
I just want to get or set Rotation values as HPB ,with COFFEE, like the cinema4D works, i can only set rotation with SetRotation, and in vectors, but i want to use the HPB degrees values , as in the c4d interface.
Example: i have a cube, I want to set Rotation 45° to H... or get the H value (45).
Hope someone can save me from this headache Thanks in advance.
On 21/05/2010 at 06:22, xxxxxxxx wrote:
The BaseObject GetRotation() function returns a vector containing the object's HPB rotation. That is, the returned vector x component holds the H value, y is P, z is B. SetRotation() works in the same way.
Try this in the script manager with an object selected:
main(doc, op) { op->SetRotation(vector(0.0, 0.5, 0.0)); }
This will set the P rotation of the object to 0.5 (note that these functions work with radians, not degrees - 0.5 radians is 28.648 degrees).
Note also that this only gets/sets local rotations. If you want the global rotation, you'll have to use a matrix. See the excellent tutorial on matrices in the COFFEE SDK.
On 22/05/2010 at 02:33, xxxxxxxx wrote:
Side note:
When dealing with the SDK, you are hopefully aware that all angles are radians, not °... i.e. H is not 45, but π/4 ≈ 0.79.
