On 26/04/2010 at 02:04, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11.5 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I have added a bitmap suscesfully. But when moving or resizing the dialog , while draging it for some seconds the bitmap DISAPEARS (!?) ... is any why to refresh the bitmap or something so it comes back ? or any way so this bug doesnt happens?
Image showing the bitmap gone:
On 26/04/2010 at 03:16, xxxxxxxx wrote:
Please post your bitmap code showing the problem.
On 26/04/2010 at 03:32, xxxxxxxx wrote:
Thanks, here some parts of the code:
BitmapGUI::Draw(x1, y1, x2, y2) { DrawBitmap(bitmap, 0, 0, GetUserWidth() - 1, GetUserHeight() - 1, x1, y1, x2, y2, BMP_NORMALSCALED); return (TRUE); }
AddBitmap(id, dialog, name, flags, x, y) { dialog->AddUserArea(id, flags, x, y); new(BitmapGUI, id, dialog, name); }
MyDialog::CreateLayout() { SetTitle(PLUGIN_NAME); AddBitmap(MY_BITMAP2, this, "header.png", BFH_CENTER, 0, 0); return (TRUE); }
On 26/04/2010 at 03:58, xxxxxxxx wrote:
Does this solve the problem?
BitmapGUI::Draw(x1, y1, x2, y2) { //to avoid blinking/flickering OffScreenOn(); SetClippingRegion(x1,y1,x2,y2); DrawBitmap(bitmap, 0, 0, GetUserWidth() - 1, GetUserHeight() - 1, x1, y1, x2, y2, BMP_NORMALSCALED); return (TRUE); }
On 26/04/2010 at 04:12, xxxxxxxx wrote:
I tried that code but same, after some seconds of resizing the windows with button pressed the bitmap just disapears, very weird. :(
On 26/04/2010 at 04:29, xxxxxxxx wrote:
Note I just realized: If i add a button to add another bitmap then when i have the bitmap disapearing problem, i execute that code, then I maximize the dialog and the bitmap appears again...Only maximizing it, not while resizing. That helps to spot the problem?
On 26/04/2010 at 07:55, xxxxxxxx wrote:
I don't normally use AddUserArea() because I prefer to use resource files, but with res files you have to use AttachUserArea() to add a user area object to the dialog. Do you have to do the same after adding one in code?
On 26/04/2010 at 08:25, xxxxxxxx wrote:
I only use the AddUserArea and the DrawBitmap , i have no idea how is with res files yet.
Is there a way to update/refresh the dialog? I notice it only refresh/updates when maximinzing, not while dragin/resizing. That can be a start to try to fix the problem.
On 27/04/2010 at 08:02, xxxxxxxx wrote:
I am not able to confirm the problem.
Here is my test code, it'a simple dialog with a scalable bitmap user area.
// be sure to use a unique ID obtained from www.plugincafe.com var PLUGIN_ID = 910000; // be sure to use a unique ID obtained from www.plugincafe.com // global variables var bmp; var text; // definition of my user area class MyUserArea : GeUserArea { public: MyUserArea(id,dialog); Init(); GetUserWidth(); GetUserHeight(); Draw(x1,y1,x2,y2); } MyUserArea::MyUserArea(id,dialog) { super(id,dialog); } MyUserArea::Init() { } MyUserArea::GetUserWidth() { return 128; } MyUserArea::GetUserHeight() { return 128; } MyUserArea::Draw(x1,y1,x2,y2) { OffScreenOn(); SetClippingRegion(x1,y1,x2,y2); DrawBitmap(bmp, 0, 0, 127, 127, x1, y1, x2, y2, BMP_NORMALSCALED); } // definition of my Dialog class class MyDialog : GeDialog { private: var ua; public: MyDialog(); CreateLayout(); Init(); Command(id,msg); } MyDialog::MyDialog() { super(PLUGIN_ID); ua=NULL; } MyDialog::CreateLayout() { SetTitle("My Dialog"); AddUserArea(5000,BFH_SCALEFIT|BFV_SCALEFIT,0,0); ua = new(MyUserArea,5000,this); return TRUE; } MyDialog::Init() { } MyDialog::Command(id,msg) { // switch (id) { } } class MyMenuPlugin : MenuPlugin { public: MyMenuPlugin(); GetID(); GetName(); GetHelp(); Execute(doc); RestoreLayout(secret,subid); } MyMenuPlugin::MyMenuPlugin() { super(); } MyMenuPlugin::GetID() { return PLUGIN_ID; } MyMenuPlugin::GetName() { return "My Dialog"; } MyMenuPlugin::GetHelp() { return "Shows programming of bitmap area"; } var d; MyMenuPlugin::Execute(doc) { d->Open(TRUE,-1,-1); } MyMenuPlugin::RestoreLayout(secret,subid) { if (!d) d = new(MyDialog); d->RestoreLayout(secret); } main() { d = new(MyDialog); if (!bmp) bmp = new(BaseBitmap, 128, 128); var fn = new(Filename); fn->SetFullString("c:\\testbitmap.tif"); bmp->Load(fn); Register(MyMenuPlugin); }
On 29/04/2010 at 01:54, xxxxxxxx wrote:
Hi Matthias, Your code worked without problems. I love you. Thanks a lot Sir!
