NodeData list
On 23/04/2010 at 08:48, xxxxxxxx wrote:
Cinema 4D Version:   11.5
hello all,
i have made new nodedata plugin and i'dd to alloc a list of this mynode in a document, store the list in it ,make recusion in it and retrive some data.
any experience ?
Franz
On 26/04/2010 at 02:12, xxxxxxxx wrote:
NodeData plugins can only be stored in SceneHooks. So you have to write your own SceneHook to save your list of NodeData plugins along with the document.
cheers,
Matthias
On 26/04/2010 at 03:18, xxxxxxxx wrote:
i am exactly in this situation ... but any sample ?
is not very clear how is possible?
Franz
On 26/04/2010 at 08:01, xxxxxxxx wrote:
I may have mixed up something here. I will try to find a solution.
cheers,
Matthias
On 27/04/2010 at 00:23, xxxxxxxx wrote:
Franz
On 20/05/2010 at 06:39, xxxxxxxx wrote:
FYI, I put together a small example of how to store a NodeData plugin within a scene hook.
Please check the code comments for more detailed information.
the NodeData plugin:
#include "c4d.h"
#include "c4d_symbols.h"
//just a extremly simple Nodedata plugin :)
class MyNode : public NodeData
  public:
      static NodeData *Alloc(void) { return gNew MyNode; }
#define ID_MYNODE 1024726
Bool RegisterMyNode(void)
  return RegisterNodePlugin(ID_MYNODE, "My Node", 0, MyNode::Alloc, NULL, 0, NULL);
the SceneHookData plugin to store the NodeData plugin:
#include "c4d.h"
class MyNode;
#define ID_MYSCENEHOOK 1025181
class MySceneHook : public SceneHookData
  public:
      //constructor; initialization and plugin node allocation
      MySceneHook()
          hookname = String("My SceneHook Name");
          mynode = (BaseList2D* )AllocListNode(1024726);
      virtual Bool Init(GeListNode *node);
      virtual Bool Read(GeListNode *node, HyperFile *hf, LONG level);
      virtual Bool Write(GeListNode *node, HyperFile *hf);
      virtual LONG GetBranchInfo(GeListNode* node, BranchInfo* info, LONG max, ULONG flags);
      static NodeData *Alloc(void) { return gNew MySceneHook; }
  private:
      AutoAlloc<GeListHead> head;        //this is the list head were the plugin node will be inserted to
      String hookname;
      BaseList2D *mynode;        //pointer to an instance of the plugin node
Bool MySceneHook::Init(GeListNode *node)
  if (!head || !mynode) return FALSE;
  head->SetParent(node);        //needed to save the node list
  head->Insert(mynode, NULL, NULL);    //insert the plugin node into the list
  return TRUE;
Bool MySceneHook::Read(GeListNode *node, HyperFile *hf, LONG level)
  return head->ReadObject(hf, TRUE);    //needed to read files
Bool MySceneHook::Write(GeListNode *node, HyperFile *hf)
  return head->WriteObject(hf);    //needed to save files
LONG MySceneHook::GetBranchInfo(GeListNode *node, BranchInfo *info, LONG max, ULONG flags)
  //fill the info structure array; only one element is saved in this example
  info[0].head = head;
  info[0].name = &hookname;
  info[0].id = ID_MYSCENEHOOK;
  info[0].flags = 0;
  return 1;    //return the number of filled BranchInfo elements
Bool RegisterMySceneHook(void)
  return RegisterSceneHookPlugin(ID_MYSCENEHOOK, "My SceneHook", 0, MySceneHook::Alloc, EXECUTION_EXPRESSION, 0, NULL);
main.cpp
Bool RegisterMyNode(void);
Bool RegisterMySceneHook(void);
Bool PluginStart(void)
  if (!RegisterMyNode()) return FALSE;
  if (!RegisterMySceneHook()) return FALSE;
  return TRUE;
hope this helps
cheers,
Matthias
On 20/05/2010 at 06:43, xxxxxxxx wrote:
Great!!!!!!!!!!!!
now is clear for me ;)
Franz
