On 20/04/2010 at 14:31, xxxxxxxx wrote:
User Information: Cinema 4D Version: r11 Platform: Language(s) : C++ ;
--------- Hi,
i am trying to figure out how i can add objects of an InExclude List to the dependency list. i thought it would be like this:
InExcludeData *objektListe = (InExcludeData* )bc->GetCustomDataType(OBJEKTLISTE,CUSTOMDATATYPE_INEXCLUDE_LIST); Bool dirty; BaseObject* temp; dirty = FALSE; // start new list op->NewDependenceList(); if (objektListe) { if (objektListe->GetObjectCount()>1) { for (int a=0;a<objektListe->GetObjectCount();a++) { temp = (BaseObject* )(objektListe->ObjectFromIndex(doc,a)); if (temp) op->AddDependence(hh,temp); } } } dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA); dirty = dirty || !op->CompareDependenceList(); if (!dirty) { blDelete(main); op->TouchDependenceList(); return op->GetCache(hh); }
but it doesnt work. the plugin is recreated all time...
any idea what is wrong here??
thanks in advance, ello
On 20/04/2010 at 21:30, xxxxxxxx wrote:
Where do you call your code?
On 20/04/2010 at 22:20, xxxxxxxx wrote:
i call it in GetVirtualObjects after i have read out the parameters
On 21/04/2010 at 01:52, xxxxxxxx wrote:
Well, have a look at the roundedtube example in the SDK, which does quite what you're trying to do.
Hope it helps
Kabe
On 21/04/2010 at 08:31, xxxxxxxx wrote:
thank you, but this still doeant handle the inexlude list.. thats the issue.
cheers, ello
edit: ok, it works now. seems i just placed the functions at the wrong place in my plugin. thanks again
