Transform UVs with CallUVCommand
On 13/04/2010 at 04:18, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :
I am trying to Transform the UV-Coordinates I generated with the CallUVCommand Function (c4d_painter).
This works fine but if I try to transform the UV-Coords it doesn't have any effect although the function returns TRUE..
Here is the Code, I would be grateful for any help.
TempUVHandle *handle = GetActiveUVSet(GetActiveDocument(), GETACTIVEUVSET_ALL);
settings.SetBool(OPTIMALMAPPING_STRETCHTOFIT, FALSE);
     settings.SetReal(OPTIMALMAPPING_DISTORTION, Rad(50.0));
     settings.SetReal(OPTIMALMAPPING_SPACING, Rad(0.0));
     settings.SetBool(OPTIMALMAPPING_PROGRESSBAR, TRUE);
     settings.SetLong(OPTIMALMAPPING_RELAXCOUNT, 0);
CallUVCommand(points, nPoints, polygons, nPolygons,
     uvwStructs, baseSelects[iSelection], pointSel, po,
     Muvpolygons, UVCOMMAND_OPTIMALMAPPING, settings);
BaseContainer settings1;
settings1.SetReal(UVCOMMAND_TRANSFORM_SCALE_X, 10.0);//scaleFactor);
settings1.SetReal(UVCOMMAND_TRANSFORM_SCALE_Y, 11.0);
          Muvpolygons, UVCOMMAND_TRANSFORM, settings1);
handle->SetUVW(uvwStructs);
On 13/04/2010 at 06:38, xxxxxxxx wrote:
I don't exactly know what is wrong with your code but the following test code works fine for me.
Bool MenuTest::Execute(BaseDocument *doc)
  BaseObject *op = doc->GetActiveObject();
  if (!op || op->GetType() != Opolygon)
      return FALSE;
  BaseContainer settings, settings1;
  TempUVHandle *handle = NULL;
  handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);
  if (!handle)
      goto Error;
  settings.SetBool(OPTIMALMAPPING_PRESERVEORIENTATION, FALSE);
  settings.SetReal(OPTIMALMAPPING_SPACING, 2.0);
  settings.SetLong(OPTIMALMAPPING_RELAXCOUNT, 1);
  if (!CallUVCommand(handle->GetPoint(), handle->GetPointCount(), handle->GetPoly(), handle->GetPolyCount(),
      handle->GetUVW(), handle->GetPolySel(), handle->GetUVPointSel(), handle->GetBaseObject(), handle->GetMode(),
      UVCOMMAND_OPTIMALMAPPING, settings))
      goto Error;
  handle->SetUVW(handle->GetUVW());
  settings1.SetReal(UVCOMMAND_TRANSFORM_MOVE_X, 0.0);
  settings1.SetReal(UVCOMMAND_TRANSFORM_MOVE_Y, 0.0);
  settings1.SetReal(UVCOMMAND_TRANSFORM_ANGLE, 0.0);
      UVCOMMAND_TRANSFORM, settings1))
      goto Error;
  FreeActiveUVSet(handle);
  return TRUE;
Error:
  return FALSE;
cheers,
Matthias
On 14/04/2010 at 02:14, xxxxxxxx wrote:
Thanks a lot, got it working now 🙂
