On 23/03/2010 at 13:22, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Where can i see a working example of MergeDocument command? or anything: I just want to merge a scene into the current one , why so hard to find info of how to do that ? Any help here? Thanks
On 23/03/2010 at 18:58, xxxxxxxx wrote:
@blackhat I suggest that you use the script log. here is how: right-click on icons under menu and choose Command Manager; write script log; you will have one result; drag the white icon to any palette of your choosing; now close Command Manager; You can save this layout as startup layout; now clic on the white icon. you will have the script log window. Now go to file---merge choose a file and open script log will show CallCommand(12096); // Merge...
ET VOILA!
NB: MergeDocument() is a c++ command.
On 23/03/2010 at 20:41, xxxxxxxx wrote:
Well, the call to the command is dead obvious, but I don't think this was the advice blackhat was looking for... most question in this forum are beyond mere scripting.
blackhat, I think it is simply not possible in COFFEE, it's not part of any COFFEE SDK afaik.
Like many other things this requires the C++ SDK.
Hope it helps
Kabe
On 23/03/2010 at 21:48, xxxxxxxx wrote:
There is xref or there is LoadDocument(), so yes it is possible. I use it to merge objects using coffee code.
Cheers Lennart
On 24/03/2010 at 02:24, xxxxxxxx wrote:
Thanks lennart , your solution about xref works ok, thanks a lot.
If someone knows the c++ command or whatever i dont' care if its coffe or c++ or java or php if i can just copy paste into a script and it works then welcome. I just want to merge a document into current one by script
Anyway by now the tcastudios Lennart solution about xref works very good, the only bad its when undo it shows each command step, but its ok by now!, thanks
On 24/03/2010 at 07:30, xxxxxxxx wrote:
This forum is not so much a copy&paste; source. It is assumed that you might do a bit of research To add an Undo function is described in the 9.5 COFFEE SDK.
