point normals
    On 16/03/2010 at 09:21, xxxxxxxx wrote:
    Cinema 4D Version:   r11
    Platform:
    hi there,
    how can i create a normal direction for a point? i suppose that i need to calculate the sum of the normals of all polygons which use that point and than divide it by the number of polygons used. but 1. how do i find out which polygons use a certain point and 2. would that be a performance issue (if i would cycle thru all polygons for every point and check if the point is used by that polygon)?
    thanks and cheers,
    ello
    On 16/03/2010 at 16:42, xxxxxxxx wrote:
    Howdy,
    Have a look at the Neighbor class.
    Adios,
    Cactus Dan
    On 16/03/2010 at 22:44, xxxxxxxx wrote:
    Thank you! Thats exactly what i need :)
    cheers,
    Ello
    On 18/03/2010 at 11:48, xxxxxxxx wrote:
    Of course you could also just let C4D tell you what they are - look at: PolygonObject::CreatePhongNormals() - the advantage to that is that phong-break edges are also taken into account.
    Keith
    On 18/03/2010 at 13:24, xxxxxxxx wrote:
    thank you.. now i did this:
    Vector n;
    Vector* phongNormal = myMesh->CreatePhongNormals();
    for (int i=0;i<pointcount;i++)
    n=phongNormal[i] _;
    Is there anything wrong with my assumption that this should return the normal for point i ? somehow it looks a bit screwed up..
    thanks for your input,
    ello
    _
    On 18/03/2010 at 13:48, xxxxxxxx wrote:
    CreatePhongNormals() creates normals for each of a polygon's points. For a cube for instance it will create 6*4 point normals. This is necessary to describe phong breaks. Depending on what you want to achieve this is maybe not really what you are looking for. I am guessing that you are looking for a way to obtain average point normals, right?
    cheers,
    Matthias
    On 18/03/2010 at 13:52, xxxxxxxx wrote:
    yes, exactly.. so do you think i should go the way using the Neighbours ?
    On 19/03/2010 at 01:04, xxxxxxxx wrote:
    Well you can still use CreatePhongNormals() and average these normals for each point.
    -build the point normals per polygon array with CreatePhongNormals()
    -iterate through all the points, GetPointR(), GetPointCount()
    -get the adjacent polygons for each point with GetPointPolys()
    -for each adjacent polygon get the point normal for the common point
    -average these normals
    alternatively
    -calculate the polygon normal for each adjacent polygon (or create an polygon normal array in advance)
    Since there is no "correct" way you have to try which works better for you.
    cheers,
    Matthias
    On 19/03/2010 at 01:29, xxxxxxxx wrote:
    thank you.. after looking again at my code i found why i got that error message. i wrote Neighbour instead of Neighbor..
    kind regards,
    ello
    On 19/03/2010 at 12:38, xxxxxxxx wrote:
    Hi, i am still having a problem here.
                      neighbor.GetPointPolys(i,&dadr,&dcnt);
                      GePrint(LongToString(dcnt));
    dcnt is always 0, but how can this be? there are actually quite a lot of points and polygons in the base mesh..
    i dont understand this.
    thanks for any input.
    cheers,
    ello
    On 19/03/2010 at 12:49, xxxxxxxx wrote:
    Sorry these two lines of code don't say much :) Please post a bigger portion of your code, for instance how you initialized the Neighbor class.
    cheers,
    Matthias
    On 19/03/2010 at 12:58, xxxxxxxx wrote:
    oh, ok.. i placed the neighbor.Init(...) in a condition which wasnt true..
    it works now. thanks for all your help :)
    cheers,
    ello
    On 11/06/2010 at 09:42, xxxxxxxx wrote:
    hi again,
    i am still struggling and i thought before further hijacking the other thread i bring this thead up again:
    here is my code for averaging.. polygonNormal returns the right polygon normals, as seen in this screen:
          padr = cloneOfBase->GetPointR();
          pol = cloneOfBase->GetPolygonR();
          numberofclones = cloneOfBase->GetPointCount();
          maxcount = cloneOfBase->GetPolygonCount();
                  if (neighbor.Init(numberofclones, pol, maxcount, NULL))
                      neighbor.GetPointPolys(i, &dadr, &dcnt);
                      if (dcnt)
                          for (int j=0;j<dcnt;j++)
                              if (dadr[j]<=maxcount)
                                  polyNormal += polygonNormal(nCalc1,nCalc2,padr,pol,dadr[j]);
                          polyNormal /= dcnt;
    any ideas??
    cheers,
    ello
    On 11/06/2010 at 10:18, xxxxxxxx wrote:
    I see that you're still not normalizing the result of polygonNormal() or of polyNormal, after you've divided it... have you tried that?
    On 11/06/2010 at 10:25, xxxxxxxx wrote:
    yes, that gave me even stranger results. what i dont understand is that it works for most of the points
    On 11/06/2010 at 11:30, xxxxxxxx wrote:
    Ok, here is some verified working code that I've stripped out to be stand-alone callable routines...
    // GetVertexNormals()
    Vector *GetVertexNormals(PolygonObject *pObj)
         LONG numVerts = pObj->GetPointCount();
         LONG numPolys = pObj->GetPolygonCount();
         const Vector *pVerts = pObj->GetPointR();
         const CPolygon *pPolys = pObj->GetPolygonR();
         // initialize neighbor class... this is used to compute m_SrcvNorms
         Neighbor neighbor;
         if( !neighbor.Init(numVerts, pPolys, numPolys, NULL) )
              return NULL;
         // Allocate array of Normal Vectors to fill in and return
         Vector *pNormals = (Vector * )GeAlloc(numVerts * sizeof(Vector));
         if( !pNormals )     return NULL;
         // Determine a Normal for each vertex of mesh
         LONG i, j, faceCnt, *pFaces = NULL;
         Vector vNorm;
         for(i=0; i<numVerts; i++)
              vNorm = Vector();          // (re)intitialize
              neighbor.GetPointPolys(i, &pFaces;, &faceCnt;);
              if( faceCnt )
                   for(j=0; j<faceCnt; j++)
                        Vector n = CalcFaceNormal(pVerts, pPolys[pFaces[j]]);
                        vNorm += !n;
                   vNorm /= faceCnt;          // average the normal(s)
                   pNormals[i] = !vNorm;     // normalize and store
              else
                   pNormals[i] = Vector(0.0,1.0,0.0);     // default case = Up for any stray verts
         return pNormals;
    // AddNormSplineObject()
    void AddNormSplineObject(PolygonObject *pObj, LONG splineLen)
         Vector *pNormals = GetVertexNormals(pObj);
         if( !pNormals )     return;
         LONG numNorms = pObj->GetPointCount();
         // allocate spline object large enough for all points
         SplineObject *splineOp = SplineObject::Alloc(2*numNorms,Tlinear);
         if( !splineOp || !splineOp->MakeVariableTag(Tsegment,numNorms) )
              MessageDialog(String("Spline Object Allocation Failed"));
              GeFree(pNormals);
              return;
         splineOp->SetName(String("NormSplines"));
         Vector *padr = splineOp->GetPointW();
         Segment *sadr = splineOp->GetSegmentW();
         if( !padr || !sadr )
              MessageDialog(String("Spline Object Data Setup Failed"));
              GeFree(pNormals);
              SplineObject::Free(splineOp);
              return;
         Matrix mg = pObj->GetMgn();
         LONG normCnt = 0;
         LONG vertCnt = 0;
         LONG i;
         for(i=0; i<numNorms; i++)
              sadr[normCnt].cnt = 2;
              sadr[normCnt++].closed = false;
              padr[vertCnt++] = pVerts[i] * mg;
              padr[vertCnt++] = (pVerts[i] + (pNormals[i] * splineLen)) * mg;
         splineOp->GetDataInstance()->SetBool(SPLINEOBJECT_CLOSED,false);
         GeFree(pNormals); // done with this now
         BaseDocument *pBaseDoc = pObj->GetDocument();
         pBaseDoc->InsertObject(splineOp,NULL,NULL);
         splineOp->Message(MSG_UPDATE);
    ...just cut/paste that into your code and call the AddNormSplineObject() routine with your PolygonObject. Once you've verified that it's working, you can either use it as-is, or reference it to figure out why yours is not working.
    On 11/06/2010 at 11:31, xxxxxxxx wrote:
    If you have any compile errors or trouble with include files, let me know.
    On 11/06/2010 at 12:08, xxxxxxxx wrote:
    thank you very much.. after first crash, i passed my doc to the function like this,
    void AddNormSplineObject(PolygonObject *pObj, LONG splineLen,BaseDocument *doc)
    and it works.. now i need to understand why it does :)
    again, thank you very very much for your help!
    cheers,
    ello
    On 11/06/2010 at 12:14, xxxxxxxx wrote:
    D'oh! I guess that your PolygonObject wasn't yet attached to the scene :). I usually test all results before using pointers like that, but I kinda threw that in there at the last minute when I was stripping out my old Class member code.
    Anyway... if you want, you can just use that GetVertexNormals() routine as-is (just be sure to GeFree() the array when you're done with it).
    Good luck!
    On 11/06/2010 at 12:18, xxxxxxxx wrote:
    i now used the pNormals to rotate my clones and now it looks like when i told you how it looked after i used the normalised normals:
    any idea? how can this be?? i'll have to recheck my code after the rotation. i just dont understand why it works for polygons, but not for points. very strange
