On 16/03/2010 at 08:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: 11+ Platform: Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- I can't seem to track down how to control the render settings that are now located under "Effect..."
I can toggle and change the "Options" etc. with renderdata() - but can't find a way to get to these sub items - for example to turn Global Illumination on.
Should be easy - any help?
Thanks,
ed
On 19/03/2010 at 06:27, xxxxxxxx wrote:
If you have obtained access to the videopost object you can enable/disable the videopost effect with the BIT_VPDISABLED bit. See screenshot below for an example.
Problem is that you have no direct access through COFFEE.
