Polygon Plane
    On 06/03/2010 at 20:13, xxxxxxxx wrote:
    Cinema 4D Version:   11.5
    Platform:   Windows  ;
    Hey everyone,
    Could anyone tell me the process involved in creating a polygon plane object from scratch?  Or point toward something that can guide me through this process.
    Thanks,
    ~Shawn
    On 08/03/2010 at 09:41, xxxxxxxx wrote:
    Anyone have any info about this.  I want to know how to create a plane from scratch.  Not creating a plane primitive, but creating a polygon object and adjusting its points and polygons to create a plane.  Is there something that could point me in the right direction.  I checked out the rounded tube sample in the SDK but I do not see where the geometry is created.
    Thanks,
    ~Shawn
    On 08/03/2010 at 12:22, xxxxxxxx wrote:
    Hi, this little example will create a quad with the given coordinates:
    BaseObject *drawPlane::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
         PolygonObject *obj = NULL;
         Vector *padr=NULL;
         CPolygon *vadr=NULL;
         obj = PolygonObject::Alloc(4,1);
         if (!obj) goto Error;
         padr=obj->GetPointW();
         vadr=obj->GetPolygonW();
         padr[0] = Vector(-100,0,-100);
         padr[1] = Vector(-100,0,100);
         padr[2] = Vector(100,0,100);
         padr[3] = Vector(100,0,-100);
         vadr[0] = CPolygon(0,1,2,3);
         return obj;
    Error:
         return NULL;
    hope it helps..
    cheers,
    ello
    On 08/03/2010 at 12:33, xxxxxxxx wrote:
    Great, thanks ello.    I want to be able to control the number of polys on the plane so I would do this by creating more polys like this?
    Thanks again.
    ~Shawn
    On 08/03/2010 at 13:29, xxxxxxxx wrote:
    yes, you just need to allocate the PolygonObject corresponding to that number, or you adjust it later on with ResizeObject(LONG pcnt, LONG vcnt)
    cheers,
    ello
    On 08/03/2010 at 15:18, xxxxxxxx wrote:
    Hi ello,   I copied and pasted your code in to my object plugin just to see how it works and I get nothing.  No polygon is created.  Any thoughts as yo why this is?
    Thanks,
    ~Shawn
    On 08/03/2010 at 23:15, xxxxxxxx wrote:
    hm. it worked at home. i'll give it another try here at work when i have a break...
    On 08/03/2010 at 23:33, xxxxxxxx wrote:
    ok, it works here, too.
    here is my whole code:
    #define pluginID 1000001
    #include "c4d.h"
    #include "c4d_symbols.h"
    #include "customgui_description.h"
    #define pluginName "testObj"
    class testObj : public ObjectData
         INSTANCEOF(testObj,ObjectData);
    public:
         virtual Bool Init(GeListNode *node);
         virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
         virtual Bool Message(GeListNode *node, LONG type, void *t_data);
         static NodeData *Alloc(void) { return gNew testObj; }
    Bool testObj::Init(GeListNode *node)
         BaseObject          *op          = (BaseObject* )node;
         BaseContainer *data = op->GetDataInstance();
         return TRUE;
    Bool testObj::Message(GeListNode *node, LONG type, void *t_data)
         if (type==MSG_DESCRIPTION_VALIDATE)
              BaseContainer *data = ((BaseObject* )node)->GetDataInstance();
         return TRUE;
    BaseObject *testObj::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
         Vector *padr=NULL;
         return obj;
    Error:
         return NULL;
    Bool Register_testObj(void)
         return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,testObj::Alloc,"OtestObj","testObj.tif",0);
    hope it works for you..
