ContantBrowser Path Q
On 03/03/2010 at 06:18, xxxxxxxx wrote:
Cinema 4D Version: R11+
Platform: Windows ; Mac OSX ;
Language(s) : C.O.F.F.E.E ;---------
Hoy, Hopefully a simple problem here:)Atm I load objects into my scene from a folder on the computer.
However I'd like to load from the ContentBrowser.If I make a "hard" path I get the object such as:
path->SetFullString("preset://SteadyCAMPRO303.lib4d/SCPROv303");
everything work fine.
But to follow the safe, platform independent way I'm trying to set a correct path,
such as:var path; var loaddocname = "NameOfObject"; // Look in UserPrefs -> Browser { println("Search User Browser"); path = GeGetStartupWritePath(); path->AddLast("library"); if(!GeFileExist(path,TRUE)) {println("User Library folder not found");return;} path->AddLast("browser"); if(!GeFileExist(path,TRUE)) {println("User Browser folder not found");return;} // path->AddLast("preset://"); if(!GeFileExist(path,TRUE)) {println("User Preset folder not found");return;} path->AddLast("steadycampro303"); path->SetSuffix("lib4d"); if(!GeFileExist(path,TRUE)) {println("User steadycampro303.lib4d not found");return;} path->AddLast(loaddocname); }
but get an error that the lib file is not found.
I suppose the "preset://" part ( out commented here) is the culprit?
How to access the :// part in the path?Cheers
Lennart
On 15/03/2010 at 08:05, xxxxxxxx wrote:
Am I thinking wrong here?
Or can I use the hard links as within a regular browser?Cheers
Lennart
On 17/03/2010 at 00:48, xxxxxxxx wrote:
I am afraid you have to use Filename->SetFullString() in this case.
cheers,
Matthias
On 17/03/2010 at 05:09, xxxxxxxx wrote:
Thanks, I see.
I don't have a Window machine to try with, how would the following
be written so it get's correct in Windows?path->SetFullString("preset://SteadyCAMPRO303.lib4d/SCPROv303");
Lennart
This should be ok. Windows accepts forward slashs. Just make if you use backslashs in strings you have to use double backslashs for each single backslash.
for example
println("c:\\test.c4d");
prints
c: est.c4d
cheers,
Matthiascheers,
Matthias
